Question about Canon BubbleJet i560 InkJet Printer
My printer (Canon i560) is not printing cleanly. I have replaced the ink and there are spaces missing in the printed document. For instance, a title at the top of the page only has half of words are seen. It is almost if when it goes back and forth when printing-it is not placing ink on each line. Any advice is appreciated.
    Top Expert:
  • Canon Master
  • 11,573 Answers
Spaces missing in the printed document
Posted on Aug 13, 2016
  • 109 Answers
You should clean ur printer nosil or head...
Posted on Nov 22, 2010
SOURCE:
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
I've performed a nozzle check on my printer and
This sounds as though the actual print head has failed or is close to failing. You can get new print-heads form you local Canon service centre - they are not exactly cheap - but cheaper than a new printer.
Feb 12, 2010 | Canon BubbleJet i560 InkJet Printer
The black ink will not print. It does when I do a clean head operation but not when printing a document
May the cardtrige is empty or damaged check it may happen with refilled one. replace it.
Jul 09, 2009 | Canon BubbleJet i560 InkJet Printer
Print heads and test prints fine......will not print ay documents
I subsequently discovered that only black would not print - the other colours did. The following solution should work for any colour
Turn on the printer
Lift the front cover so that the ink tanks line up at the front
Move the grey arm to the right of the yellow upwards
Remove the ink tanks (in my case 4)
Carefully lift out the plastic holder for the ink tanks, this I believe holds the print heads
Clean the head(s) using cotton buds and injet refill ink cleaning fluid. I get mine from Tescos with my refill inks.
Replace everything and hopefully your printer will be o.k. Mine was
Jun 05, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print properly after ink reload
try to clean nozzels and run the alignement utilityt.
Jan 21, 2009 | Canon BubbleJet i560 InkJet Printer
No colored ink
Some printers will allow you to print with one cartrige. Send a document and see.
Jun 25, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560
may be ink level is too low,check it first,make sure delete the all pending documents
regrads
prasanna
Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
151 people viewed this question
Clive
Clive
old marine
old marine
