Question about Motorola Mobility H300 Wireless Headset
Pairing bluetooth with new phone
Do you think i can pair a Motorola H300 with my LG VIEWTY? It won't find the device when i search through bluetooth on this phone.
  • Shoikot Sep 18, 2008
    I can't pair my Motorola H300 with my T-mobile Dash. I turned the headset on and went to the Bluetooth option,"Add New Devices" on my
    handset. But it didn't find any Bluetooth enabled devices. Do you have any idea how I can pair it with my handset?
You have to hold the on button until it is a solid blue light not flashing 5 or 6 seconds then it is ready to be paired.
Posted on Dec 01, 2008
Turn headset off if its on then hold button down until you get a solid blue light! Now your bluetooth can be paired to your phone! Go to bluetooth on phone then to paired device then hit new and it will search for new devices! It should say Motorola H300 when finished! Simply click on it and it will tell you to enter pass code! Enter 0000! Now your phone should be paired with headset and able to work!!
Posted on Jan 08, 2009
I have a Samsung model # SCH-R500L and I have a Motorola H300 . I am trying to set it up and my phone can not find the device . I had it the headset hooked up before to another phone.
Could you help me?
Barbara
Posted on Aug 28, 2008
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
http://www.in.lge.com/Product/Manual/KU990.pdf
Jan 11, 2010 | LG KU990 Viewty
Morotola H300 with Blackberry Device
re-pair and add to trusted devices be sure to use 0000 for passkey
USER GUIDE
Oct 08, 2009 | Motorola Mobility H300 Wireless Headset
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
Need a pass key for a motorola h300 in order to pair it with a samsung sphm 540
the pass key is 0000
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
Jan 22, 2009 | Motorola Mobility H300 Wireless Headset
Pass key
pass key 0000
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
repeat step 1.
PAIR
Your Phone
device.
from 0000.
YOUR HEADSET
Jan 13, 2009 | Motorola Mobility H300 Wireless Headset
I have a LG scoope that I'm trying to hook my motorola H350 up to it. I lost the instructions and I don't really know if it will go with it. I need help!!!!!!
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 12, 2009 | Motorola Mobility H300 Wireless Headset
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth with samsung sph-640
Moto H300 should be "0000"
Jul 29, 2008 | Samsung SPH-a460
NEED TO RESET
try pairing and entering the code 0000
Dec 27, 2007 | Motorola Mobility H300 Wireless Headset
Motorola Mobility H300 Wireless Headset Logo
178 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
