How do I change HP 5610 print cartridges. - Office Equipment & Supplies
    President:
  • 1,314 Answers
How do I change HP - gtabseps.giftp://i.fixya.net/uploads/images/gtabseps.gif" alt="gtabseps.gif" class="h_mi" /> Introduction Follow the instructions below to replace the print cartridges. This document applies to the following products:
  • 5605
  • 5608
  • 5610, 5610v, 5610xi
Replace the print cartridges Step one: Remove the print cartridges
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on. Figure 1: Press the On button to turn the product on How do I change HP - c00442142.gif c00442142.gif 1 - On button CAUTION: If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Figure 2: Open How do I change HP - c00442143.gifor c00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. How do I change HP - c00316910.gife 3: The print carriage c00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    How do I change HP - c00442144.gif The print cartridges in the proper position c00442144.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Posted on Jun 22, 2008
  • Kevin Shafer
    Kevin Shafer Jun 22, 2008
    Step two: Install the new print cartridge
    1. Remove the new print cartridge from its packaging and, being careful to touch
      only the black plastic, gently remove the plastic tape by using the pink pull tab.
      Figure 5: Remove the tape
      1 - Copper-colored contacts
      2 - Plastic tape with pink pull tab (must be removed before installing)
      3 - Ink nozzles under tape
      CAUTION:
      Do not touch the copper-colored contacts or ink nozzles.
      Touching these parts can result in clogs, ink failure, and bad electrical
      connections.
    2. Slide the new print cartridge forward into the empty slot. Then gently push on the
      upper part of the print cartridge forward until it clicks into the socket.
      • If you are installing the tri-color print cartridge, slide it into the left slot.
      • If you are installing a black or photo print cartridge, slide it into the right slot.
      Figure 6: Insert the print cartridge
    3. Close the print-carriage access door.
      Figure 7: Close the access door
    Step three: Align the print cartridges
    The HP All-in-One prompts you to align cartridges every time you install or replace a
    print cartridge. Use the following steps to align the print cartridges from the control panel.
    1. Make sure you have letter or A4 unused plain white paper loaded in the input
      tray, and then press
      OK
    2. The HP All-in-One prints a print cartridge alignment sheet.
      NOTE:
      If you have colored paper loaded in the input tray when you align
      the print cartridges, the alignment will fail. Load unused plain white paper
      into the input tray, and then try the alignment again.
    3. Lift the lid. Place the top of the alignment page face
      down in the left front corner of the scanner glass. Close
      the lid.
      Figure 8: Load the alignment sheet on the glass
    4. Press
      OK
      to begin the alignment.
    5. The HP All-in-One aligns the print cartridges. Recycle or discard the print
  • Kevin Shafer
    http://h10025.www1.hp.com/ewfrf/wc/docum...
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer not printing, message appears saying cartridges dont fit.
Have you recently changed your cartridges? Try replacing them, if you haven't printed for a while the cartridges will dry up and you will not be able to print.
May 31, 2010 | HP Officejet 5610 All-In-One InkJet...
OFFICEJET 5610 COLOR AIO Printer: I have an hp 1530 that wont print in color after w...
Open HP solution center.
click on settings >>> Printer settings >>> click on Color tab..
select print in color. Click on OK.
Now try to print
May 07, 2010 | HP Officejet 5610 Color All-in-One Printer
Hp officejet 5610 All-in-one having 'cartridge error', need help to solve it. thank you.
Remove both cartridges and clean the electrical contacts with a dry cloth. Clean the contacts in the carriage, inside the product too. Put the cartridges back in.
If that doesn't work, remove the black cartridge from the printer and try to print something. If the color one prints, you need to change the black cartridge. If the color one won't print, and the black does, then you need to change the color cartridge.
Apr 11, 2010 | HP Officejet 5610 All-In-One InkJet...
Very slow printing - HP 5610 all in one
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
How do you change the ink carterage in an hp officejet 5610v all-in-one?
Hello !
To change the ink cartridge(s) in your printer,
Remove the cartridge.
Take the new cartridge from the package.
Remove the strip from the cartridge without touching the metal back.
Insert the cartridge.
Hope this helps.
Oct 04, 2009 | HP Officejet 5610 All-In-One InkJet...
"Cartridge Error: Cart. on left is not intended for this printer"
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o15
Apr 19, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP officejet 5610 all in one is not printing black colour. Message flashed is align left cartridge. However, despite changing the cartridge same result.
u have to clean ur cartridge nosel u have remove cartridge from the printer then take normal hot water then put the cartridge nosel on it then take tissue papaer to clean the cartridge
Feb 23, 2009 | HP Officejet 5610 All-In-One InkJet...
243 people viewed this question
k24674
