Jwin model #JK-777
Can't get cd door to open. It has three discs in it and I can't get them out.
  • 868 Answers
You will have to remove the cover shell and get the jam un jammed.I'll assist you if you need .
Posted on Jun 22, 2008
Have had this JWIN model JK-777 turntable/am-fm/cassette/cd player unit. It won't power on now. Checked the outlet, no problems there. Does this unit have a fuse?
1. It's more likely the problem is a broken power cord or dirty power switch. If you've been in the habit of yanking the cord to unplug the unit instead of pulling directly on the plug, or somebody tripped over the cord, the power cord is probably broken right at the plug.
2. Changing a blown fuse without finding and repairing the fault that blew the fuse will only give you another blown fuse. It's not like the old farmhouse with too many things plugged in on the same fuse... A blown fuse in audio equipment is usually the result of a shorted speaker driver transistor. The transistors come in pairs; if one is bad the other has been overloaded and should be replaced also. That's a job for an electronic technician.
Nov 22, 2017 | Jwin Audio Players & Recorders
JWIN Model JK-777 won't power on. Checked wall outlet, no problems there. Does this unit have a replaceable fuse?
All microwaves have a main power fuse. You have to remove the outer cover. It will be located near the back by the power cord.
Nov 22, 2017 | Microwave Ovens
Jwin JK-777 How do you access the turntable belt?
Most turntables have an access point under the platter matt. The matt should peel up.
Nov 30, 2015 | Audio Players & Recorders
Jk-777 turntable belt
Take measurements of your old belt and then order one a tad smaller in circumference to account for the stretched condition of your belt and go to the following web site for belts. MCM Electronics Home and Pro Audio Video Security and Test Equipment
Oct 08, 2015 | Audio Players & Recorders
CD Changer/turntable MDL Fisher DAC-145.
Hello....Give you local SEARS store a call and inquire...I've used them in the past...Their repair center does excellent work and repair more brands than anyone I know....If there are any up-front costs...they'll let you know...Try it and let me know....I hope this was helpful......PEACE.......
Feb 06, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Fisher 143a CD Changer
You wont be able to play any new format CDs on an old Fisher or any other older make . It 's the internal decoder logic that's needed. And older players dont have it.
As far as top-loaders..Do a websearch . I dont know of any.
Jan 27, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Kenwood XD 550 stereo start-up problem
this normally happens with a lot of sets! It usually happens during a Power Failure, Power Surge (Fluctuation) and if the wire of the component is taken out from the wall outlet while the system is on...To get rid of this problem all you need to do is to press the Display button on the main unit, it is located just below the main display! Voltage Selection has got nothing to do with this problem...
Jun 29, 2008 | Jwin JK-777 Nostalgic Stereo System with...
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
No Play No Eject
Jan 26, 2008 | Nakamichi MB-70 6-Disc CD Changer
JWin Problem
Is this a retail CD? Is it badly damaged? Any scratched at all, or is it a CD burned from a computer?
Sep 07, 2007 | Jwin JXCD935 MP3 CD Player with Anti-Skip...
102 people viewed this question
