Question about Cameras
Canon 20d ,error code 99,shutter keeps firing rapidly, shut it off, removed batteries, but when you reinsert batteries it firea and when you turn it back on it continues to fire also I don't have a menu screen no more
  • 2 more comments
  • kwestman Nov 10, 2008
    I have the exact same problem occuring on my Canon Rebel 350 XTi
  • rachelqld Jan 05, 2009
    This exact problem happend to me with my 20 D Canon. Does anyone have any advice? rapid fire even when batteries are removed and inserted, constant err 99 message.
  • Anonymous Mar 03, 2009
    i have the same, going off to canon
  • Anonymous May 17, 2009
    Same problem...tried cleaning it even replaced the small batter where the big one goes ,didn't help.
    Anyone heve thiers repaired yet for this?
5 Suggested Answers
  • 1027 Answers
SOURCE: The shutter continues to click in rapid concession
Make sure the camera is OFF when placing the battery in it, and have the mode dial (Top left side) set to the green rectangle for automatic mode. Then turn ON.
Posted on Jul 15, 2008
SOURCE: Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Posted on Apr 08, 2009
smartr10U
  • 1305 Answers
SOURCE: The shutter continues to click in rapid concession Canon 20d
Check to make sure that you don't have it set on continuous. Check the lcd display and see if the shutter icon showing a mulitple as opposed to single frame image.
You should be able to choose between single, mulitiple and timed shutter releases...
Posted on Sep 08, 2009
  • 80 Answers
SOURCE: Err 99
this is what the canon people say to do for error 99
Read this!!!
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked eaaa19b.jpgb9433a1.jpggood luck!! have a nice day :) :) :)
Posted on Apr 08, 2010
Error 99 when using Quantum Transceiver
Error code 99 is a non specific error code a sort of catch all. Remove the lens and clean the contacts (lens and camera), remove the battery and the memory card. Leave the camera in this state for about 10 mins, enough time to discharge any build up of charge or static. Reinsert the battery and the memory card and reattach the (cleaned) lens switch on leave for 5 seconds and press the shutter button to see if this has cleared to problem.
Jul 09, 2014 | Canon EOS-20D Digital Camera
What is error 99 in canon eos 20d
It's a frustrating catch all error and needs service.The camera may have any one of numerous issues or lens issues. If you have more than one lens, see if the error occurs with both lenses on. If not then it's a lens error. A camera repair facility can plug unit the camera and download a more accurate troubleshooting code. Royal Camera Service in Hanover Park, IL is good source for this problem. The replaced the shutter on my 20D when I got the error 99 code.
Feb 06, 2013 | Canon EOS-20D Digital Camera
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
Canon 20D gone shutter crazy , clicking away on its own error code 99
The Canon 20 D is a fantastic camera but the weak point is the shutter it last about 70 to 80,000 actuation then causes a bunch of problems. In Canada it cost about $180.00 including the shipping to the repair depot to get it fixed.
Jun 21, 2010 | Canon EOS-20D Digital Camera with 55-200mm...
Feb 19, 2009 | Canon EOS-20D Digital Camera
Err 99
Read this!!!
Aug 07, 2008 | Canon EOS-20D Body only Digital Camera
Canon 20D error 99 shutter stuck
Exactly same problem, shutter clicks until battery removed. Power may be on or off.
Apr 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Cameras Logo
283 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
