Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Changing thermal fuse and lamp
We're fairly mechanical. Is changing the thermal fuse and the lamp something we could do?
Thanks!
Tammi
  • tamarahull Jun 23, 2008
    Since posting my question, I did some more googling and learned that our problem may be the lamp bulb (it was the original) and the lamp board. We've ordered replacements and are keeping our fingers crossed that they will bring our big behemoth tv back to life.
  • 84 Answers
I would not recomend you changing the fuse even though it sounds simple. the new one is modified and has to be rerouted, for saftey factors if not installed properly the tv could get hot and melt things or worse. the lamp is designed for customers to change so go ahead if you need to chang the lamp only.
Posted on Jun 22, 2008
Sony tv model kds-60a2000
Please count the amount of blinks before it pauses. The number of blinks will say if the door isnt latched all of the way or if the thermal fuse has popped above the lamp area. Hope its a 6 blink as that is the thermal fuse which is easy to bypass or replace.
Sep 20, 2016 | Sony Televison & Video
Error e401
This is a fuser warm up error. First check the thermistor if it is dirty clean it, check lamp & thermal fuse. Changing the thermistor &/or thermal fuse usually fixes this issue!
Nov 02, 2013 | Panasonic Workio DP-2330 Printer
Sony kf-ws60s1 front red light flashes 6 times after lamp replacement. Need thermal fuse part number
hello!
your issue has nothing to do with "thermal switch". while you have replaced the lamp, you could lose a piece of plastic hardware, in front of the lamp housing. It pushes auxiliary interlock switch, right under the front of the lamp compartment. If you take lamp out, use flashlight and shine inside. There is a little switch at the bottom. Try to make the lamp housing push it, without breaking anything. you could get "generic" lamp with housing, which is not correct. Anyway, that's the deal. Also: don't forget to install lamp door and turn the handle clockwise! there is another switch. I've seen people who forget to put that door back! Really!
good luck,
Alex.
Mar 06, 2012 | Televison & Video
I changed the lamp but the lamp light keeps blinking and the tv won't turn on.
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
OR
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
I hope this helps.
May 18, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
6 blinking lights after changing replacement bulb
You have an open thermal fuse in the lamp housing. The fuse has an upgrade and is only accessible from the back of the TV>
Apr 15, 2009 | Televison & Video
Sharp copier z 57 II black copy, lamp replaced but still not on?
Nearly all of them have thermal fuses or small circuit breakers.The thermal fuse is in series with the the lamp wiring and is physically very near the lamp.If the lamp stays on for too long, it overheats the thermal fuse which then sacrifices itself to protect the lamp.Good Luck
Apr 02, 2009 | Sharp Office Equipment & Supplies
Replace a lamp on a photocopier
Hello, the C5 code will only show up after the C7 code -- Fuser temp. to low. First put a meter on the Thermal fuse and the Thermistor and see if it is blown. The fuse and thermistor are under the black ( usually) fuser cover which runs the lenght of the fuser. If the fuse and /or thermistor are blown, replace. The lamp will not come on if the fuse or thermistor are blown. If the fuse and thermistor are good then take the end cap off of the fuser ( usually 1 screw) and disconnect the brass (usually) from the lamp. Check the lamp ( continuity), is the lamp okay. If not replace the lamp. If all of these are good then check the Solid state relay unit ( usually in the lower right hand side looking at the back of the machine with cover off). If the relay is good then you have to replace the PWB-A, the main board.
Jan 12, 2009 | Office Equipment & Supplies
Changing ink cartridge
I need help, I have a canon MP530 just changed the cartridges, but it tells me to check ink. Is it necessary to fill the lg.space for another black cartridge for it to work ?
donnat1111@aol.com thankyou
May 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Flashing lights?
Hi there
This sounds like a faulty Powersupply.
Before replacing it , try replacing the fuse on the board first.
Apr 14, 2008 | Fujitsu LPF 7200 Multimedia Projector
Green Light blinks, no picture, bulb new
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic tv1.gif.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find. Radio shack1.gif also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
must be crimped.
Jan 14, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
206 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
