Question about Philips Televison & Video
Philips 50P8341 50 in. Rear Projection the blue is not converging
  • Philips Master
  • 8,617 Answers
You need to replace the convergence ICs and also a few of the 6.8 Ohm 1 watt resistors as that model will usually burn about 4 of the resistors. Your ICs are STK392-110 you need two of them. You can get replacements at the following link and they also provide free instalation instructions with pictures so you can do the repair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jun 21, 2008
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
Can't adjust blue vertical convergance.
Hi
blue vertical is defective convergence amplifier Stk ic and need to replace
Thanks!
Jul 08, 2009 | Philips 55PP9401 55" Rear Projection...
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
Aug 17, 2008 | Philips 60P8341 60" Rear Projection...
Philips big screen projection tv
sounds like the Convergence ICs are getting ready to go. Does it appear as a outline almost 3D? If so its convergence if its more like a glowing halo its coolant in the blue CRT that needs changing.
Jun 20, 2008 | Philips 51PW9363 51" Rear Projection...
Phillips 43PP6360/79
if the hase your refering to a glowing halo its the blue coolant that needs changing. If it causing a 3D image then its the convergence ICs need changing
Mar 23, 2008 | Philips 60PP9202 60" Rear Projection...
Philips rear projection tv prob
You need to replace the conversion ICs. Both of them.
Mar 09, 2008 | Televison & Video
Philips 50P8341 50 in. Rear Projection Television
Sounds like the blue convergence IC s bad. They are relatively easy to replace if you can solder they cost around 10.00 each and you should change both the red and the blue.
Feb 09, 2008 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
