Headphones with mic / external speakers
In order to conference I got a pair of headphones with mic. It has 2 jacks for the back of the pc so I had to unplug the speakers. I certain cases I need the external speakers. I picked up Durabrand USB powered speakers hoping that would solve it - NOT. It too has a USB for power and a jack for the back of the pc.
How can I have both headphones with mic and external speakers?
  • bwesson Jun 22, 2008
    Thanks for the wake-up call. It is the ideal fix.
    President:
  • 1,314 Answers
Does your computer have front audio ports? If so, you can just plug it in there. Otherwise you need a single male 2 dual female converter to plug into the speaker port.
Posted on Jun 21, 2008
Pc headphone volume driver
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or you might have to depending on your operating system
Click start Control Pannel
Click on Hardware and Sound
Click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Feb 18, 2013 | HP/Compaq P4 System - WinXP Pro/Office...
Dell 546 desk top. No audio from external speakers. Downloaded driver. No help. Any ideas?
If you are using Windows, try going in the the Device or Hardware manager and removing the device. Then, look on the menu bar at the top to rescan for hardware changes. Sometimes this is the best option. I am assuming that the speakers work, but, I would plug in a set of headphones to be sure. Also, sounds dumb, but ensure that you are not plugging the speakers into the mic jack (microphone) or the line-out jack (low level output) instead of the headphone jack.
Nov 05, 2011 | Dell Inspiron 546 MT PC Desktop
Using headphones
You can get a set of speakers that has a headphone jack on front (it will shut off the speakers when headphones are in) or you can unplug the speakers and plug in the head phones. Some PCs have a red and green jack in front - plug in headphones to the green, you should have the speakers shut off till you unplug. All else fails they make a headphone/mic extender that sits like a hockey puck on the desk, has cables to the mic and speaker jacks on back of the PC and on the puck part has a jack for speakers, mic and headphone - some switched manually by you, some switch when the headphones plug in. If you had posted the model I could see if your machine has front red and green jacks.
Jun 19, 2010 | E-Machines eMachines Desktop PC
My external speakers wont switch off when I plug a pair of headphones into the jack
first u are talking abt en u internal spekar when u plug headphone or speakar did the both spekar ply the sound i mean internal & ext. (problem in your head phone pin or in jack which not push the jack properly) or jack pin touch cutoff pin check it
Mar 05, 2010 | HP Compaq nc8000 Notebook
Wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Jan 09, 2010 | Audio Players & Recorders
Speakers work in the front headphone jack on my Dell PC, but not in the audio jacks in the back of the computer
I think most computers do not have headphones in the rear, just LINE OUT, which has no enough volume to be used for headphones.
Dec 03, 2009 | Bose Companion 2 Computer Speakers
Headphone Jack Problem
Go to the icon tray and double click the speaker icon. Have a look in the Advanced controls to see if you have taken the mute off the pc speaker. There might also be an option to play sound on the pc speaker simultaneously with the headphones. If so, uncheck the dual play box so the sound will not play through the pc speaker when you have the headphones plugged in.
Aug 06, 2009 | Acer Aspire One D150-1587 Netbook
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
Speakers work with ipod not with laptop
First thing, you have plugged in to the wrong point, plug in the speaker to the headphone slot(mostly light green in color).
MIC point is specifically for MIC not speakers.
The point which works for your headphones would work perfectly for speakers.
Mar 15, 2009 | Logitech X-240 Computer Speakers
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Feb 20, 2008 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
