Question about Black & Decker 9072CTN Cordless Screwdriver
Remove the pins on a B&D electric screwdriver 9019, to remove the cover and to change batteries
Use a end of a small nail to tap it on thru'. replacement is just the reverse [don't need new pins if you are careful!]
Posted on Jul 17, 2008
Can't get the cover off
Remove the first screw, peel back the 12 amp sticker, remove the second screw, use a screwdriver to pry the top and both sides of the cover. The cover should now be free, then remove the grommet that holds the power and throttle cable to the cover to completely remove it.
Aug 24, 2011 | Ryobi ZRRY46501 Factory-Reconditioned 12...
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
What is the procedure to changing an keyed ignition lock?
Removal
Disconnect the negative battery cable with the proper size wrench and place away from the battery.
Insert the key into the ignition lock cylinder and turn the key to the run position.
Remove the steering column cover on a tilt steering wheel model by pressing the upper and lower section of the cover together and pulling free from the mounting plate. Remove the steering column covers on a non tilt steering wheel model by using a Philips screwdriver and unscrewing the mounting screws.
Disconnect the electrical connector from the ignition switch by lifting up on the release tab and pulling.
Press the ignition switch actuator pin by pushing a small screw driver into the key lock cylinder, while doing this pull the ignition switch out of the ignition switch housing.
Installation
Insert the new key into the new ignition switch and turn the key to the run position. Insert the new ignition switch into the ignition switch housing. Wiggle the switch back and forth until the actuator pin mounting hole is aligned and falls into place.
Install the electrical connector back into the connector housing by pressing it in with your hands.
Place the steering column covers back onto the non tilt steering wheel and insert mounting screws. Tighten screws using a Philips screwdriver. Place the steering column covers over the tilt steering wheel and press the upper and lower portion together to snap covers back into the mounting plate.
Pull on the ignition key to ensure switch is locked into place. Turn key to the "off" position and remove the key. Insert the key and start the vehicle.
Hope these help.
Jan 28, 2011 | 1992 Ford Crown Victoria
How to replace main heater fan
Blower Motor REMOVAL & INSTALLATION Front Fig. 1: Front heater blower motor assembly 89696g02.gif
Remove the glove box to access the front blower motor, which is on the firewall 89696p02.jpg
The blower motor vent tube helps to cool the blower motor for efficient operation 89696p04.jpg
A ratchet with extensions makes removal of the retaining screws easier 89696p06.jpg
  1. Disconnect the negative battery cable.
  2. Open the glove box door. Gently squeeze the retainers at the rear of the box inward and allow the box to swing downward. NOTE: If additional access is required, unfasten the glove box hinge retainers and remove the assembly.
  3. Label and disconnect the electrical harness from the blower motor.
  4. Remove the blower motor housing tube and/or blower motor cover.
  5. Remove the blower motor retaining screws.
  6. Remove the blower motor from the A/C evaporator. To install:
  7. Install the blower motor in the A/C evaporator and tighten the retaining screws securely.
  8. Install the blower motor housing tube and/or blower motor cover.
  9. Connect the electrical harness to the blower motor.
  10. Reinstall the glove box and close its door.
  11. Connect the negative battery cable.
Rear Fig. 2: Service cover push pin locations 89696g03.gif
  2. Remove both rear passenger seats.
  3. Remove the three push pin retainers from the lower edge of the auxiliary heater and air conditioning service cover.
  4. Lift the service cover outward and upward to remove.
  5. Label and disconnect the electrical harness.
  6. Remove the blower motor housing tube.
  7. Loosen the three retaining screws and remove the blower motor. To install:
  8. Install the blower motor and tighten retaining screws securely.
  9. Install the blower motor housing tube.
  10. Connect the electrical harness.
  11. Position the service cover and install the three push pin retainers from the lower edge of the cover.
  12. Install both rear passenger seats.
  13. Connect the negative battery cable.
Dec 19, 2010 | 1998 Ford Windstar
How to change baTTERIES SCC100R
The following procedure should be followed for battery removal prior to disposing of the product:
1. Make sure the clipper is unplugged from any outlets so you don't risk an electrical shock.
2. With a flat head screwdriver, gently pry the top cover from the unit. This will expose the internal circuitry compartment.
3. With a Phillips head screwdriver, remove the four screws on the
circuitry compartment top cover.
4. Locate 6 latches around the perimeter of the circuitry compartment and pry each to loosen top cover.
5. Remove cover to expose the batteries and circuitry.
6. Clip the wires connecting the batteries to the circuit board and
remove the batteries.
Nov 26, 2010 | Remington SCC100R
How do you replace the battery in a ironman triathlon sleek digital watch
Thank you for contacting FIxYa.
Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
  • Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • OR take to a professional jewelry store/watchmaker.
    Good luck.
    Aug 21, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    The tip of my AC charger broke off on the contact post of my samsung sph-a620. A new charger cannot make contact for recharging purposes. I cannot see how to disassemble the phone to access that electrical...
    To disassemble the phone, you need to get he appropriate screwdrivers and follow the processes below;
    1. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers and unscrew the aerial.
    2. Remove the screws,
    3. Next remove the 2 rubber stoppers & screws above the main screen,
    4. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
    5. Unclip the ribbon,
    6. After removing the ribbon cable, carefully lift the metal part. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with just the screen and the keypad rack.
    7. On the circuit board, you'll see the charging port and the broken charger that is in it.
    8. Try to pick it out with a pincher, and if you cannot, then you have to replace the charging port.
    9. Disconnect the charging port and replace it with a new one.
    10. Reverse the process to reassemble the phone back together.
    11. Take care.
    Jun 22, 2010 | Samsung SPH-a620/VGA1000
    2001 ford focus
    If your Ford Focus is not starting, and you know the battery and alternator are good, the problem could lie in the ignition system. The ignition switch is a whole cylinder inserted into the steering column that connects to the starter motor. When you change an ignition switch, you are also replacing the key.
    1. Remove the dashboard panel below the steering column in your car; it should be screwed in place. Remove the steering column's upper cover by releasing its clips with a flat-head screwdriver.
    2. Look for the audio control switch---a small device sticking out of the steering column that acts like a remote control. If one exists, release the switch's plastic locking tang with the screwdriver, and unplug the electrical connector to remove the switch.
    3. Loosen the steering column by releasing the locking lever, and remove the steering column's lower cover by pulling out the screws with the screwdriver.
    4. Use your ignition key to turn the switch to the left---the position that would activate the accessories but not start the car. Insert the screwdriver into the hole in the top of the cylinder to depress the detent spring, and pull out the cylinder with the key inside.
    5. Insert the new key into the new ignition switch, and line up the switch inside the steering column so it's in the same place the old switch was in when you removed it. Make sure the detent locks into place; then turn the switch so it's in the "Off" position.
    6. Replace all the covers and panels you removed to access the cylinder, along with the audio control switch, if applicable, in reverse order of
    Things You'll Need:
    • Small flat-head screwdriver
    • Ignition switch and key
    Tips & Warnings
    • Older Ford Focus models may have a different method of removing and changing the ignition switch. Check an automotive guide for your particular year and model.
    • Always disconnect the negative (black) battery cable before working on the ignition or any other electrical component of your car.
    I hope helped with this (remember rated this help) Good luck.
    Nov 11, 2009 | Ford Cars & Trucks
    Black & Decker 9072CTN Cordless Screwdriver Logo
    312 people viewed this question
    Top Black & Decker Drills Experts
    JOHN LAPIER
    Phil Rivera
    Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
