Question about Sony XM-754HX Car Audio Amplifier
Hooking Up A Sony XM754HX To Jensen BP210
I got the Sony XM754HX amp and i want to hook it up to the Jensen bp210
http://mobile.jensen.com/jensen/JensenProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_ID=STR_CATEGORY_LOADED_BASS_ENCLOSURE&ACTION_PRODUCT_ID=BP210
The rating on the subs says 900 watts peak. I doubt that true just because it's Jensen. I guessing it needs 300 rms. I don't how I'm going to wire it and how can I give it 300rms. I was thinking connecting the mono terminals on the left and the mono terminals on the right together then going to the terminals on the side of the sub box.
diagram
RCA's From Head Unit
_|_ _|_
________________________________
+ - - + + - - + |____+ Positive Sub Terminal
| | ____ - Negative Sub Terminal
|_________|__________________|
  • 1 more comment
  • the-resource Jun 21, 2008
    srry the diagram changed after i posted my problem.
    ..._|_ ....._|_....
    Amp Speaker Out Puts
    .......________________________
    .. ....|.................|........................|____+ Positive Sub Terminal
    .| ................|.............................. ____ - Negative Sub Terminal
    .|__________|_________________|
  • the-resource Jun 23, 2008
    they are DVC and 4ohm
    Problem Solver:
  • 30 Answers
Hi .let me see if i can help u out ...need more info on the speaker..are the 8ohm or 4ohm ? and are the single are DVC?.....from what i can see u can bridged the amp..and u must connet the subs in series or just connet each sub +/- to +/-..and that will give u a stereo mode... u will still get great sound
Posted on Jun 22, 2008
  • james  boyone
    james boyone Jun 23, 2008
    okay they are DVC that is good u will have to wire them up in series..so that u will not overload the amp...let know if u know how to wire up each sub .to read 4ohm.each
Sony XM-GTR4A
contact sony .... or check your head unit is recieving
Mar 29, 2014 | Sony Car Audio & Video
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Aug 18, 2010 | Jensen Car Audio & Video
How should i run my Jensen A600HLX Amplifier if i am using it to power 2 10inch Rockford P1 Subwoofers?
U need to check the impedance of your woofers .If they are 4 ohm i would reccomend hooking them in series, which is the positive output of your amp will go to the positive of one woofer, the negative of that woofer goes to the positive of your other woofer and the negative goes to the negative output of the amp.If that amp is bridgeable this will give u a good bass and the impedance will be 8 ohm so your amp will run cool and stable
Jul 30, 2010 | Jensen A600HLX Car Audio Amplifier
Hooking a turntable with it's own pre amp to a computer and/or a home theather system gemcquaid mcquaid@northlink.com .
Check your inbox.
Hook the output to Aux. As for your PC, that would depend on your sound card. Basically, the same.
Mar 01, 2010 | Sony PS-LX250 Turntable
Amplifier and sub installation in a boat.
norally grounding them in the same place is ok but it could just theres not enough power from the amp too power two subs try hooking up one and see if that gives you the sound your looking for
Jul 09, 2009 | Car Audio & Video
Hooking to amps to a power acoustik ptid-7250n
Can you post a bit more about the components, as in the make and model of each?
  1. Head unit in the dash
  2. Sub amp
  3. Stereo amp
Feb 13, 2009 | Jensen VM9510 Car DVD Player
Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Dec 08, 2008 | Jensen LXA400 Car Audio Amplifier
How do i hook up the r.c.a to the back of VM9312
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is on...you will blow amp
Mar 18, 2008 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
201 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
