Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Mode Selection Fault
For some reason, my SD300 keeps going into movie mode, even when the switch is in the photo taking mode. I can turn the camera on, with the switch in the camera position, and it will start up in camera mode, but after a few seconds switch to movie mode (usually just as I am about to get a good picture!) Not sure what to do with it. Whether to give up and buy a new one, or try to get it fixed.
  • 1 more comment
  • Canon Lover Jun 27, 2008
    I have the exact same problem. I think it's because the camera is getting old for lots of use.
  • treehause Aug 05, 2008
    canon sd300 problems:
    movie mode keeps kicking in while in foto mode. a red hexagon shows on the the screen and now... the lcd is cracked.  but i live in new zealand and darntoothysam does not ship to me.
  • ripclaw_ffb Nov 28, 2008
    I have the same problem. Where can we purchase a new mode switch and how much does it usually go for?
  • 489 Answers
Hi
Your mode position switch could just be damaged or the switch on the outside of the camera might not be properly lined up with the switch on the inside. You have to open up the camera body to see what I mean, its not hard, just make sure you take out the battery first.
If you need the mode switch, its pretty easy to take off, I just pulled one off an SD300 to see whats involved and its pretty simple.
As for international shipping... Im starting to do it more, but only via US Priority Mail International which is $12 for a flat rate envelope. I just don't like stuff disappearing during transport and that's why I don't like shipping to the other side of the globe.
If you need the parts please let me know, we will get the shipping figured out.
Good luck from: Darntoothysam com
Thomas
Posted on Sep 26, 2008
Cant get it off movie mode whats wrong
You can open the case (take the six small screws out two on the bottom and two on each side) Both the front and back will come off you may have to work it a little to get them apart. Look at the back and you will see a three position switch if it is to the far right move the switch to the center position and turn the camera on see if you are out of movie mode if you are verify that the plastic switch cover on the back of the case is not broken (it may just have been misaligned. If after moving the switch and you are still in movie mode you have a component problem and you will most likely need to send it in or buy a new camera. Hope this helped
Jul 22, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
I can't get it off movie mode
You can open the case (take the six small screws out two on the bottom and two on each side) Both the front and back will come off you may have to work it a little to get them apart. Look at the back and you will see a three position switch if it is to the far right move the switch to the center position and turn the camera on see if you are out of movie mode if you are verify that the plastic switch cover on the back of the case is not broken (it may just have been misaligned. If after moving the switch and you are still in movie mode you have a component problem and you will most likely need to send it in or buy a new camera. Hope this helped.
Jul 11, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera not turning off and when ON,always in picture preview mode
This is a problem on the motherboard, sort of like a solenoid that controls the functions of on/off mode and video still mode. it needs a service and possibley a patrt replaced Hope its unjder warranty as it expesnive
Jun 23, 2009 | Canon PowerShot S3 IS Digital Camera
I turn the camera on and the screen shows blue with a no image sign. Is it stuck in some mode where its looking for photos? The card is clean and empty. I cannot take any photos. I also use a...
Check the mode selection switch. It should be adjusted in the mode you desire to work. Also click the shot button and keep it pressed for about 2 seconds. If still not working properly then switch off the Camera and remove the battery and replace it after about 2 to 3 minutes and then try again.
Jan 23, 2009 | Fuji FinePix S5000 Digital Camera
Camera does not go into picture taking mode
Camera mode selection dial has failed. Replace the mode dial/switch/button.
Nov 13, 2008 | eVision ClearView Digital Camera
Multiple pictures
Dear ACO107,
Please turn on Cyber-shot in camera mode and press Menu, select Mode, select Normal, OR got to Camera Mode Selection Button (top of camera near power button) and select Auto (Green Color) symbol. Problem would be solved.
May 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
UNIQUE PROBLEM: Camera stuck on Movie mode
It's a small world. I have an Ixus V2 on the bench with exactly the same problem. The sliding button on the camera mates with a switch soldered to a flat ribbon cable inside the camera. There are two small teeth which move the internal switch left ot right. What's happened is one of those plastic teeth has snapped off the external part and now it can't push the switch anywhere. If you pulled the camera apart you could push the switch into either record or review but that's it. It will stay in either of those positions. Which is a bummer. The only way to fix it is to buy the complete flat cable ribbon with switch attached and boy it's a long cable. Except for sending it away for repairs (expensive) buy a damaged one on Ebay and do a transplant. Just make sure it's suffering the same fault.
Jul 19, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
90 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
