Modern Fan - optional downrods for eclipse ceiling fan
Problem for Modern Fan - optional downrods for eclipse ceiling fan
Ceiling fan problem
By Beresford - usenet poster
My fan bearing has worn out and I have to replace the fan.  I took the
old fan down and noted that the mounting system consisted of a large
hook suspended from the ceiling which mates with a hard rubber or
plastic spool affixed to the end of the rod attached to the fan.   I
was surprised to find that all of the fans available in our area are
mounted in a different way.   The fan rod has a ball mounted on the
end of it.   The ball somehow fits into the bracket on the ceiling.
This will mean that I will have to replace the mounting system unless
I can find a fan that will mate with my existing rod which is 1.05 "
od.   Most of the local fans take a rod with a .75 " od rod.
My fan has the following information on a plate mounted to the outside
of the motor:  Model T300 Series,  Americana Electronics Prod.
Anybody have any ideas how I can get something to work using the
existing mounting system?
remove NOSPAM for email.  Thanks
Solution #1
posted on Aug 11, 2005
Not Rated)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
No, the hook goes through the box but not attached to it.  It goes
through a hole in the box and screws into a 4x4 beam that serves as a
roof joist.  It is a gabled roof.  The beam is incased by 1x6 cedar
planking giving the appearance of being bigger.   The box is mounded
to the bottom  1x6 but the hook goes through a hole in the box up into
the 4 x 4.  I am concerned that the box is not attached well enough to
carry the weight of the fan.
On Mon, 16 Jul 2001 05:02:58 GMT, "HareBall" <N @nowhere.com>
Was this helpful?
Yes
No
Solution #2
Not Rated)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
How is the box mounted to the 1x6? If it's fastened by wood screws, they
should hold just about any fan you can buy.
If you decide to replace the screws or add any, make sure you drill a pilot
hole for them.
TR
Was this helpful?
Yes
No
Solution #3
Not Rated)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
I have never had a problem with a box that was screwed to the rafter, but if
I am putting in a new installation, I will buy one of those fan mounting
kits.  Really couldn't tell you if it would work for you in your situation.
If you could get it up into the ceiling, it would be a good way to mount the
box and then you could be confident it would stay up.
HareBall
Was this helpful?
Yes
No
Solution #4
Not Rated)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
From what I read it was suspended from the ceiling.
HareBall
Was this helpful?
Yes
No
Solution #5
Not Rated)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
From the description he gave, I'm assuming the hook was suspended by the
box.
TR
Was this helpful?
Yes
No
Solution #6
Not Rated)
Jimmy NY
Rank: Apprentice
Rating: 0%, 0 votes
Don't forget to make sure the box is supported well enough to hold the fan.
I am assuming the hook was screwed directly into the rafter.
HareBall
Was this helpful?
Yes
No
Solution #7
Not Rated)
Janice
Rank: Apprentice
Rating: 0%, 0 votes
Yes, as long as you put the solid piece of the bracket downhill so the ball
of the fan doesn't fall out--you'll see what I mean when you get the fan. If
by some chance it doesn't work, you can go to Lowe's and get a vaulted
ceiling kit.
TR
Was this helpful?
Yes
No
Solution #8
Not Rated)
Chandler
Rank: Apprentice
Rating: 0%, 0 votes
If the ceiling box is mounted properly, it will hold the weight with no
problem. Never seen a household fan NOT mounted on one of those box-bracket
thingies, personally. They hold chandeliers up with those, and a modern fan
isn't much heavier. Don't wanna swing from it, though. If you have reason to
believe the box isn't well mounted, there are all sorts of old-work
solutions that can be added from above (if you have access), or you can even
sink a piece of 1-by into the drywall accross 2 joists, and mud and paint it
to hide it, with the box retained by ears behind the wood.
aem sends...
Was this helpful?
Yes
No
Solution #9
Not Rated)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
What's so hard about changing the mounting system? It should be attached to
a metal box with 8/32 machine screws, so just take it down and put the other
one up.
TR
Was this helpful?
Yes
No
Solution #10
Not Rated)
Lizzy
Rank: Apprentice
Rating: 0%, 0 votes
The roof is gabled and the fan is mounted on a slope.  I am wondering
if the other mount system will accomodate that?
On Sun, 15 Jul 2001 00:07:56 GMT, "Tom Reedy" <txr9 @earthlink.net>
Was this helpful?
Yes
No
Popular Solutions for Modern Fan - optional downrods
Questions and Unsolved Problems for Modern Fan - optional downrods
Do you recommend Modern Fan - optional downrods for eclipse ceiling fan?
Answer
Answer
How to replace a 3 way ceiling fan switch?
Answer
The pilot lite is on, yet when fuel knob is on, and thermostat turned to 77 dergrees , No fire in... (More)
Answer
Have a Hampton Bay Ceiling Fan Model # UC7067RC which has been rewired to cause light and fan to run... (More)
Answer
I need the part that attaches to the fan blade to the motor. Homlmes Fan#8oM6/Model HASF1516
Answer
I want Harbor breeze 4 inch 3/4'' I.D. Ceiling Fan Downrod
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Electric Fans Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
