Philips 23pf5320/28 does not power up - Televison & Video
  • Anonymous Jan 31, 2009
    Light is green, but does not turn on.
You need to replace ther power supply board. A semiconductor (P10NK80ZFP) wil short and cause nearby resistors and diodes to also short.
Steve
Posted on Apr 05, 2009
  • matt martin
    matt martin Jun 10, 2011
    Capacitors (location)C2079 and C2080 are bad. These are 35 volts at 1000Mfs at 105 degrees. The next weak or bad capacitor will be C2075 which is a 25 volt 100Mf at 105 degrees. This will cure your TV set. Thanks for letting me complete a repair for you!
Philips LCD TV power cycles on and off during power on sequence. TV will not power on.
This typically indicates a power supply issue. In order for the TV to protect itself, instead of staying on and causing over heat and potential fire, it shuts off. Contact Philips for possible warranty info.
Jun 06, 2016 | Philips Televison & Video
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
My philips hts3520/94 not working, the power button blinks maybe 3 times white and then stays white ....it alawys happens when trying to power it up...i tried to unplug the power for almost 24 hrs and
That trick usually works. Suggest you ask Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Dec 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
Power point burnt out
Power point, means, the power supply regulator section? It will be best to contact the authorized service center for Philips in this case, as availability of the Philips power board is rare in open electronic spare part market. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Philips Televison & Video
Power Supply for Philips HTS-3261
My Philips 3261/98 Power Module Dead also, I replaced on IC on the power PCB, can work already
Jul 02, 2013 | Philips Audio Players & Recorders
Can you supply a replacement 13 V, ac/dc adapter (HP5230, HP 6414/16/24)?
Bernabeu, we do not supply anything at fixya except information. I will ad links to where you can purchase a power supply. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Power TM 6 6ft Long Cable AC ADAPTER Philips Norelco Satinelle Electric...
Amazon com UpBright AC Adapter Charger For Philips Satinelle Soft Epilator...
NEW AC Power Adapter Charger For Philips Satinelle Epilator HP6400 HP6401...
Results for Epilator philips charger
Jan 24, 2011 | Philips Satinelle HP6409 Epilator
I HAVE A PROBLEM WHIT CONNECTION OF PHILIPS "POWER
Hi.
Send me Your e-mail address.I can send scan of operating instructions.
My adress: slaweksci@op.pl
Best Regards
Nov 06, 2010 | Philips POWER SUPPLY (41644158) Power...
Philips model no 29pt8319/57r
Can you tell me some more then "power supply fault". I need some more information ...
Feb 23, 2010 | Philips Televison & Video
I need an owners manual
Your best bet is to search the Philips website.
I note that the American website contains more products listed than does the Australian site.
I have located a 300W Power Inverter however, it is a US2-GGE819.
If it is an older stocked item, then you would need to use the Contact section of the website to contact Philips to obtain a copy of the manual.
TO SEARCH the Philips SITE do the following:
1. Copy and Paste the following link to navigate directly to the US site:
http://www.support.philips.com/support/find_product.jsp?userLanguage=en&userCountry=us
2. Type the product description ie., power invert. Press <enter>
3. Read through the list of products to locate yours.
I hope this helps. Regards,
Feb 09, 2010 | Philips Gemini 300W Power Inverter...
Televison & Video Logo
408 people viewed this question
Top Televison & Video Experts
Electro Med Services...
