Put a fuel system cleaner in it
I will put 5 gallons of gas then have some one turn the ignition on while listening to the water pump if you hear a noise coming from the fill up hole then most likely your water pump is good is not i will check fuel pump rellay and fuse replace as necesary check pupm sound if no sound replace fuel pump.
i will put 5 gallons of gas then have some one turn the ignition on while listening to the fuel pump if you hear a noise coming from the fill up hole then most likely your fuel pump is good is not i will check fuel pump rellay and fuse replace as necesary check pupm sound if no sound replace fuel pump. hope the correction will serve you well. good luck
