Question about Acer Aspire 5100 Notebook
Laptop Overheating My laptop (Acer Aspire 5100-3357) which I bought just less than a year ago started overheating a few months ago. I didn't know why every time I left it on it was off when I came back, and then one time I was there when it happened. It seems to only happen when the screen is closed, but it will be running fine and then suddenly make a strange beep and shut off. It can't be turned back on for an hour or so, (I assume because it has to cool off?) I keep it on a cooling rack with a fan running under it at all times, and it has always lived in a cold air conditioned basement. Is this a known problem with the Acer's and is there any warrenty that would cover this sort of problem? I have read how-to's on taking apart your computer, and blowing it out with air but I don't feel comfortable taking it apart myself. It has also started to be much slower and the video card might not be working correctly, I get a lot of jumping and skipping in visuals and it locks up if certain programs run such as windows media player.
Clean the Fan.
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Posted on Dec 31, 2008
I have read lot of same type of problems,with acer,if it is under warranty send it before end, there is fee of 449.00 for out of warranty notebooks. my 5100's have problems,very unhappy! with acer good-luck!
Posted on Jun 24, 2008
3 Suggested Answers
  • 37 Answers
SOURCE: Acer Aspire 5100 Freezes
I am not sure which you are talking about either. But I will venture to say that I had a similar problem once where setup would not complete on my system either. I initially thought that I had a bad or dirty disc but later after running a few tests, I found out that my HDD was full of bad sectors. Thus I ended up replacing the HDD and all is well. I would try running a stand alone formatting software or you could try doing a complete format vs. a quick format during Windows setup. If setup still won't complete after a complete format then run a surface scan or a HDD regenertion program to verify the integrity of the drive. This will tell you if you have a bad drive or not.
Posted on Sep 23, 2008
SOURCE: I NEED ALL THE DRIVERS FOR ACER ASPIRE 5100 - 3357
i need all the drivers for acer aspire
Posted on Oct 06, 2008
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
My Acer Aspire 5517 keeps shutting off...
1. Check if the air duct inlet and outlet are free and free of dust.
2. If needed, clean it with a hard brush and vacuum cleaner.
3. Check if the fan is rotating, if not replace the fan unit.
4. Check if the fan is clean of dust, if so clean it.
Nov 16, 2011 | Computers & Internet
Acer Aspire 7520, running windows Vista, keeps overheating and shutting down. It is fairly new - less than a year old. Does not run for much more than 20 minutes before shutting off. It was purchased in...
Sounds like there is dust where the cpu fan is and its blocking the ventilation path in the laptop. If you can take apart the laptop to expose the fan, I would make sure the fan is free of debris. Clogged CPU fans will cause the laptop to overheat cause the air has nowhere to go.
If you do that and the laptop is still overheating then the motherboard is going bad unless your not using the correct charger for it. If you use a charger that puts out more voltage then whats needed then that could cause the laptop to overheat so you might need a new charger.
Apr 15, 2010 | Acer Aspire 7520-5185 Laptop
Acer Aspire 4315, making noise near fan
You would need to open it, has the laptop been dropped? This is the only way I know that could cause this problem. I suggest you fix this problem because it will cause overheating of you chips, that will eventually cause failure. Opening a laptop is not for novice, unless you trust yourself you can do it, have it done in a shop that fixes laptops. Some electronic shop can do this for you at a resonable price.
Jun 30, 2009 | Acer Aspire 4315-2963 Notebook
Bluetooth activates by itself, random letters appears when typing
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
Jun 12, 2009 | Acer Aspire 2930-4661 Notebook
Acer Aspire one won't start up because of harddisk security
ask the theif who sold it to you. maybe he knows the password
Mar 07, 2009 | Acer Extensa 5620-6119 Notebook
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5100 Notebook Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
