Even if you update the firmware of yoour Sony PS3 it is not capable of sending out TrueHD or DTS Master audio formats bit to bit. That is the reason why you are not able to choose TrueHD or DTS Master from your listening mode. The only time you will be able to choose these modes is if the receiver receives these signals from the source. To know what signal you are receiving, you can press the "Display" button in front of your panel. When you do that I believe what it would give you is PCM which is uncompressed audio.
Hehe
In most cases, the issue might be with
the Java content on the new Blu-ray discs is making this issues. The
Blu-ray technology is developing everyday and adding more and more features to
the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the
latest firmware update available from the
manufacturer (who ever it is). Going ahead with the first step, please install
the latest firmware update available for the Blu-ray Player.
Please click the following link to get the
latest firmware update available for your Blu-ray
Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
You can review the "Important Notes"
and "Firmware Update Instructions" on the page to get the
instructions to install the firmware update.
If the issue persists
after installing the firmware update, the would have been with the disc. Check
the disc with another player, try different discs with same player.
If the Blu-ray Player is
not at all playing any Blu-ray disc including the previous played ones, then it may require service.
Won't receive signal for Dolby True HD and DTS Master audio for ps3. I am using HDMI cables!
I have the PS3 with the 2.60 firmware, the onyko 706 receiver. HDMI 1.3 cable from PS3 to the receiver. No matter what the audio format is on the Disc, all I get on the receiver's display is THX cinema. I currently have a 5.1 setup that has been setup by the Audessy.
