Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Sound no picture
My akai pdp4294ed has no picture but its sound. i saw that you can reset it to the original state but my remote is an akai bn59-00347 and the instruction that appers here TRY THIS USING THE REMOTE. 1-PRESS BRIGHTNESS 2-PRESS THE FREEZE KEY 3-PRESS THE MENU KEY 4-PRESS ENTER THIS WILL RESET EVERYTHING. I dont have any brightness key or freeze key please any help on how to do it with my remote model or how can i fix this. Also red that by changing a few capacitors from the power board will fix it but i have no clue on which one. Thanks
  • hattiee Jul 06, 2008
    Sound but no picture
    Problem Solver:
  • 17 Answers
I've repaired them
Posted on Aug 07, 2008
I can get no sound on my Akai tv
whenever something electronic goes wrong try resetting to factory default. If the device is not broken this will restore it to working condition. the restore function should be found in the settings menus somewhere
May 28, 2015 | Akai Televison & Video
AKAI STB 8309 DUR HD with no remote.Anyone knows the codes of that remote.
Akai is really made by Samsung----You might want to check with them or try to price and look for an ORIGINAL replacement remote--Universals are a pain as you have discovered and even if they program will be missing a number of key features the original remote had.
They are by no means "Universal" for programming or use.
Mar 22, 2012 | Televison & Video
Need to reset and don't have a remote. Have DirecTV, which, when the picture went out and then the sound, instructed me to reset the TV.
hi, you will need to find out what model remote you need and find it at an auction site or remote online store, i need a remote for a akai 27 inch i found them online but im waiting till i find it used at a auction site a bit cheaper. hope this helps
Jun 04, 2010 | Audiovox PLV31199S1 19 in. LCD TV
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
Picture but no sound
if you get sound from dvd then you know the audio output circut is good in tv try other video inputs for sound composite component
May 05, 2010 | Akai CF2791 27" TV
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
DISTORTED PICTURE
Problems with voltage regulation is the usual case for what you are describing.
Jerry G.
Apr 29, 2008 | Akai PT4799HD Rear Projection Television
No sound or picture
Try 2 things:
1. If you have a cable box with the yellow/white/red outputs, use a compatible cord to run the 3 to another input on your TV (ie input 1 vs cable). and/or
2. Do a Factory reset. Hold the "menu" button on your TV then on your remote hit "menu" then "8" then "select" and go to "factory reset". You may have to unplug the TV as it may freeze on "factory reset". Replug it then try it out.
Hope it works.
Apr 03, 2008 | Hitachi 51F510 51" Rear Projection...
Akai hdtv 1080i, No Sound
I sounds like a bad filter in the sudio supply circuit finally took out the sound output chip or the power supply that controls the sound circuit. its a soliud state set and there are no user replaceable parts inside this set. Unless you have had solid state repair experience, please be safe and call in a pro to assost you in this repair. good Luck ps Please rate this thread
Oct 19, 2006 | Akai PTH5498 54" Rear Projection...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
165 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
