Question about Toshiba Computers & Internet
How to change settings for modem connection ehernet wiring
    Master:
  • 848 Answers
Go to control panel and open modem and change the settings you wanted
Posted on Jun 21, 2008
How do i connect to my wireless thats in my home...says connect ehernet cable my desk top is in the other room i have wireless why do i need too connect with cable
You don't.
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and once you are prompted, select "Wireless" rather than ethernet. Ethernet is only when you have the cable plugged directly into the console.
I am always available for chat.
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Cqan you please tell me what wires connect where on the router box and where else
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
May 19, 2010 | Computers & Internet
Will not connect 2 internet
can u please elaborate on the problem .. like what is the kind of modem, how do u connect .. i.e using wired or wireless ... do you have any other pc in the house connecting
Mar 24, 2010 | Linksys Wireless-G WRT54G Router
D-Link wired Router is not communicating with my cable modem. I get internet connection with modem but when I connect router Internet connection can not be found. I know I am hooking it up correctly. Can...
Make sure that your computer is able to go online through the modem.
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Jan 29, 2010 | D-Link (DI-711) Router
Connecting my ps3 with a wireless modem
ok you will need a ethernet cable connected from your pc/laptop to your ps3
1st you will need to change sharing settings on your o2 modem
to do this goto manage network connection in there right click on the o2 mobile connection go down to properties go in to properties in there go to sharing and allow other users to use this connection.
2nd when setting up the ps3 you need to change one setting.
on the ps3 go to network settings go dowm to internet connection settings
select costom >wired connection >auto detect> ip adress = automatic >
dhcp = do not set > dsn = automatic > mtu = manual set this to 1420 >proxy sever = do not use > upnp = enable . that it just test your connection .this works good for me wit o2 the only setting changed was the mtu any thing between 1400 to 1450 will work fine ps add lostxbox as friend in psn
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
I have installed a Belkin G Wireless Modem Router-F5D7634-4 Internet connection is fine, but I'm not able to connect with wireless connection.Can someone help me to configure this please?
You have to configure your router's wireless setup. To do that, you need to connect you computer/laptop to your router using ehernet cable (cat5). Once you're done, open internet explorer/firefox and enter your router's ip address (can be found in your manual or at the back of your router), you will be ask for username and password (just enter the default if you dont change it before, username: admin , password: none/blank. depends on manufacturer). After you provide and entered those information, you're now on the setup proccess. Just go to wireless setup menu and select your options there. Remember, enable DHCP for the router to automatically assign an ip for your computers. Goodluck!
Jun 24, 2009 | Belkin (F5D6230-3) Wireless Router
Change settings
The router ports autosense the speed of the device that you are connecting to it. If your xbox is set to run 100 mb the ports will run 100, if the xbox is set for 10 then thats what it will run. Test the speed of your internet connection with a wired pc and then test directly into your modem and see what speeds that you get. You can test your speed here:
www.speedtest.net
Jun 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
What settings do I use/change to connect wirelessly to my wireless modem,at the the moment I am using Ethernet cable as modem has 4 ethernet inputs.Just simply want set up Dell desktop 3100 Dimension...
To set up a wireless network one computer still has to be wired, ie. connected to the router with ethernet. This will allow the other computers in the network to connect wirelessly if they have wireless cards installed. Hope this helps.
Mar 12, 2009 | Computers & Internet
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
