Question about Saeco Easy Espresso Machine
Saeco Easy - Switching Reg to Decaf
I have a Saeco Easy which I have probably run 2500 shots through and it is wonderful. But recently I have wanted a Decaf shot. So I carefully empty the bean holder all the way into the grinding mill and drop in some decaf expresso beans. Im not 100% confident that the beans I am grinding actually are making it in the same cup 1:1. I suspect there may be up to 1 shot worth of grounds buffered between the mill and actual shot. I dont know how to prove this (unless I have white coffee beans), but I had to disassemble an earlier Easy so my suspecion is not with out some experience.
Does anyone know for sure?
Entkalkung
Posted on Aug 08, 2008
Saeco Easy - Chamber clogging with coffee
After quite a bit of digging (not a lot of information out there on this), I found a handful of others who said that oily beans will cause this problem. Sorry I can't give you better news on that. If you do wish to try a new bean though, you might want to check out this site: http://killerbeans.com/site/home.html The satisfaction guarantee is legitimate, and this is the only place I know where you can actually find out the roast date of your order (though you have to ask, he's happy to let you know).
Aug 21, 2007 | Saeco Easy Espresso Machine
I put ground coffee and it doesnt come out only water.. is it my brewing unit ??
If you are putting the ground coffee into the little override container for decaf coffee I had the same problem because I was using a bit too much ground coffee so it dumped it out rather than making a cup. Once I ensured that I was using one level scoop only, not more, it worked.
Feb 28, 2010 | Saeco Magic De Luxe Espresso Machine
Grinder is not functioning, apparently, resultant brew is between tan and clear.
HOw oily are the beans you are using ? cause oily beans will clogg up the grinder causing none or little to come out. Try running some really dry beans threw decaf beans are generally drier than most. If the amount of coffeee being ground doesnt increase then the grinder will have to be taken apart and cleaned out.
Dec 17, 2009 | Saeco Talea Giro Espresso Machine
Want to have a coffee using the 2nd coffee grind dispenser
no one has helped me yet. It made a half cup, but I think that may have been a fluke. The 2nd time I tried it to fill up 1 cup of decaf, it again failed. I just can't find my manual.sigh...
May 02, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Easy automatic espresso machine
Heating element is probably burned out and needs replacing.
Aug 28, 2017 | Saeco Easy Machine super automatic...
Heat temp and time
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
Curious
Try to descale your machine, if there are calcium in the boiler then the coffee will have wrong temperature and tast bad.
Aug 06, 2008 | Saeco Aroma Espresso Machine
Extremely short battery life
do you use alkeline batteries? if yes then they would end in 20-25 shots. Instead, use rechargable batteries of 2500 mah which will last long, very long. On my Cybershot H1, they give aproximate 350 shots with single recharge.
Go for Sony Original Batteries or Uniross brand also works fine.
2300 mah/ 2500 Mah any will work.. :-)
Nov 25, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Saeco Easy Espresso Machine Logo
105 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
