Question about Sony PlayStation 2 (PS2) Console
I can read any game
My cinsole looks like it is working fine. But I can not play any games. When I insert a disc, the "system navigator" screen comes up all the time... any tricks or idea to solve this problem?
Thanks
Well, what i did was i took apart my ps2 and cleaned the lens on the disc reader gently with a tissue... before, it only played 5 of my 28 games,,, now it plays all of them... try that...
Posted on Jun 22, 2008
The discs could not be read and they have no scratches and look fine then
The Wii console will not play game discs (disc is not recognized)
System displays either error message "Unable to read disc" or "Disc could not be read"
Note
Wii Game Discs are region locked, and can only be played on hardware from the same country where the game was released. (A European game cannot be played on a North American system, for example.)
What To Do:
The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
Verify that the console is placed correctly.
If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically. (Learn more)
Verify that the disc is being inserted properly.
If the console is placed horizontally, the disc label will face upwards.
If the console is placed vertically, the disc label will face to the right.
Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
If the disc is dirty, try cleaning the game disc. (How to)
If the disc is damaged or scratched, it will need to be replaced. Please click here for replacement options.
If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Make sure only licensed accessories are being used. Unlicensed products do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
Nov 17, 2012 | Nintendo Wii Console
I inserted my game and it said "the game disc
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance
Feb 20, 2011 | Nintendo GameCube Console
My game cube will read disks but after a while it skips and says disk read error
The Disc could not be read:
  1. Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  2. Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting
  1. Some games may need to be cleaned. Clean each disc with a soft, slightly damp cotton cloth (use water only). Clean them from center towards the edges; do not use a circular motion. DO NOT use paper. Once they are cleaned, dry the disc using a dry portion of the cloth and wiping in the same style as you did to clean the discs. After all of the water is gone, let the discs sit for at least two minutes to completely dry before inserting any of them into the Nintendo GameCube.
  2. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  3. Ensure the games are being loaded properly. With the power turned off on the system, replace a Game Disc (printed side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen. Try this with a few of your games.
If Troubleshooting doesn't fix the problem, and it is happening with all your games, then your system will need repair. Check out our convenient repair options.
Dec 08, 2010 | Nintendo GameCube Console
The disc in the game cube does not turn. the error say, game disc cannot be read.
Troubleshooting - Multiple Discs
Single Disc
Nov 28, 2010 | Nintendo GameCube Console
Disc wont read
Single Disc
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
Aug 06, 2010 | Nintendo GameCube Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Please insert ps2 format disc?
Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
Mar 05, 2009 | Sony PlayStation 2 (PS2) Console
Error Screen
Playing Super Smash Bros. Brawl? Click here for specific help.
If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures (click here).
    If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available
  • Jul 22, 2008 | Nintendo Wii Console
    PS3 wont read discs
    maybe ur system is corrupt so u might have to contact sony and ask them about it, did ur games work fine before?
    May 13, 2008 | Sony Playstation 3 (PS3) Console
    PS2 Loading & Playing
    change you'r ps2 lence ribon.-goodguy electronics-sri lanka -094785180737-
    Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
