Question about Bosch WFVC5400UC Washer
Bosch 500 series washer E:27 error code? - Bosch WFVC5400UC Washer
  • 1 more comment
  • Jeff James
    Jeff James Nov 21, 2015
    Ok, I had this error code E27. Ends up this is actually how to reset it. Dont bother powering off or any of that stuff. Just do this, with the door closed switch the selector to cold to the left ( perm. press) then just wait 3 minutes. Thats it! Dont touch any buttons just wait. It will do a series of 3 beeps while you are waiting. If it will not reset then most likely you need a new door switch ( interlock ). This worked for my vision 500 series washer. Not sure about all the other ways I have read about because none worked for me. Again, there is no need to power off or to press any other buttons. I hope this helps!
  • victoria macisaac
    victoria macisaac Jul 24, 2017
    I heard the first beep
  • victoria macisaac
    Yay it worked
    New Friend:
  • 8 Answers
Turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
Posted on Jun 14, 2013
  • 3 more comments
  • Christina Marie
    Christina Marie Nov 24, 2013
    You sure are a brillian! This worked! NO WAITING FOR ANYTHING!! Thank you so much
  • mike meng
    mike meng Mar 01, 2014
    great! it worked again. thanks a lot
  • Karen Lapienski
    Karen Lapienski Sep 23, 2014
    You are brilliant! Love YOU!! This was awesome! Means a lot to me.
  • Annette Catania
    Annette Catania Jan 28, 2018
    Thanks. That worked.
  • Shaun Medeiros
    Shaun Medeiros May 24, 2018
    OMGosh!!! Worked for me too. See how long it lasts. They dodn't make them like they used to... just saying
    Top Expert:
  • Bosch Master
  • 9,472 Answers
E27 means there is a problem with the door lock. Unplug the machine for 5 minutes and try again. If the error code returns you will need to replace the door lock assembly.
Posted on Nov 21, 2010
  • 3 Answers
Instead place the machine on a wash cycle and the E:27 error will beep. ignore this error for about 10 min. The machine resets and it should start working. this worked for me hopefully it works for you
Posted on Sep 04, 2012
  • Christina Marie
    you sure are a brilliant man, i dont know how you knew that but it worked omg!!!! thank you
  • Christina Marie
    sorry wrong person
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi I had the same problem and to fix it, I holded Delay Start and Spin Selection and move the nub to the Cold position Perm Press then I hit the Start button while still holding the Delay and Spin button then I put back the nub to off and the machine has reset itself. Hope it help.
Posted on Jun 10, 2017
SOURCE: e13 error code with my
As with some of the other solutions to this error after unplugging from the wall and popping the cover off and unlatching the door with the "emergency" latch release I was able to drain the tub wuth my shop vac then removing the cover to the pump cleanout was able to vacuum the remaining water from the pump . I discovered several buttons and other debris in the fins of the pump, removed those and reassembled. Good as new!
Posted on Aug 10, 2009
SOURCE: Bosch Washer flashing E:
John-I have the same problem. I called service, they told me to unplug it (or turn off the breaker) for 30 mins, then turn back on. That should reset it. However, for me, it didn't do a thing. He said if that didn't work it's time for a service call.
Posted on Aug 12, 2009
  • 410 Answers
SOURCE: bosch nexxt series 500. error eo4
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
sclarke7
  • 222 Answers
SOURCE: Bosch 500 series washer E:27 error code?
error 27 is the door lock, unplug machine for 30 mins or so, then replug, possibly closing the door too hard messes up the sensor/switch in the door lock assy, if all else fails replace door lock.
Posted on Nov 16, 2011
E:27 error on bosch 500 series washer
turn the dial to the off position. Hold down both the delayed start and spin select buttons and turn dial to the left one click (cold position). you should then here the door unlatch. let go of the buttons. you will see some other codes p 01, p 02. turn dial to off. it should work fine after this. it worked for me. this should be in the manual.
May 15, 2012 | Bosch WFVC6450UC 500 Series Vision Front...
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch WFVC5400UC Washer Logo
12,107 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
