Question about Brother HL 5250DN Laser Printer
OFFLINE My brother 5250 goes offline and will not come back on. I have to delete the printer and re-install. This printer is plugged into a linksys router and I am using windows vista on one computer, and windows xp home on other computers. Is there a driver or update that corrects this problem?
  • Marie Murrell Jun 27, 2008
    Sometimes it will go offline on the XP computers as well. However, I have done a lot of research and I am refining my network settings so things are getting better. I already had the drivers your link was to....however, it is VERY hard to follow through on exactly what I was supposed to do go get those drivers loaded. I think it would be best to assign a static IP address to the printer. Do you know where I can find specific instructions on how to assign the Brother HL5250 a static address?
    I do not know how to build an IP Port.
  • 2,794 Answers
Here is the answer for Vista support on your printer from Brother:
http://www.brother.com/E-ftp/windowsvista/us.html
Does it print on the Windows XP computer just fine?
Posted on Jun 21, 2008
  • Tim Babcock
    Tim Babcock Jun 27, 2008
    Do you know how to build an IP Port?
  • Tim Babcock
    Tim Babcock Jun 28, 2008
    Go to control panel.
    Select printers.
    Find your printer on the mouse and select properties by pressing the right mouse button.
    Click on ports.
    Select add port.
    Select standard TCP/IP port. If Brother created special software for IP ports for your printer then select that.
    If you know your router settings and you have an address in mind, you press New port and run the wizzard. Type in the IP address the you want your printer to be. Press next. Once the port is created. Check it off and select apply. Make sure that IP address is setup on your printer as well. Most printers will set one up automatically for you if the printer is connected to the network and IP addressing is turned on.
Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Jan 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
I have a Brother MFC 6490CW printer. I have been using it wireless for the past 6 months. When i had a problem with the auto tray select, i reloaded the printer and it constantly goes back to OFFLINE. ...
If you are setting up a wireless printer in Windows 7 then there may be different issues that can appear while installation. If the status of your printer is offline then you have to reinstall the drivers of printer on Windows 7-based system.
Nov 23, 2010 | Brother Office Equipment & Supplies
I cant print any documents my brother MFC-255CW says offline and i cant get it to work
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer offline? won't print
please go to start menu, select printers and faxes or control panel to select printers and faxes open it, right click on your printer and scroll down to select use printer offline. then u are safe to print start ur printing. dont forget to rate me when it works am sure it will work. thanks
Jul 17, 2009 | Brother HL-2040 Laser Printer
My brother laser printer 2170w is saying it's offline and I have no idea how to get it back online
just right click your printer icon in printer properties.it will pop out some options.in that options it will also pop out the offline option just click that offline option it will turn in to online option.if u find it hard just uninstall the printer drivers and reinstall it again from the printer driver installation cd.it will work properly.
thanks.
Dec 15, 2008 | Brother HL-2170W Laser Printer
How to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Oct 12, 2007 | Brother MFC-8860DN Printer
Brother HL 5250DN Laser Printer Logo
1,526 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
