Question about Sony DAV-S400 System
No surround sound(headphone theatre mode)
Hey guys! well i wrote to you a week or so ago, about my sony dav-s 400 being stuck in headphone theatre mode, i followed the instructions and re- soldered the dry joints i could find, well actually, the only thing i could find was the brown capacitor was loose. so i've soldered it back in place, being very careful, and still no change, could it be something else? cheers, mark.
  • brettrigby10 Sep 09, 2008
    I have the same problem with my Sony DAV-S400. It seems if I push the back of the unit in (requires some force) it "clicks" and I get full surround sound back.
    I've taken the unit apart, but see no obvious culprit; all the solder looks in good condition.
    I'm going to take the unit apart once more and have a look, I suspect
    that it's the back panel with all those connections that is the
    problem. It may be a simple solution, like tightening / loosening the
    screws.
    Brett.
  • arsenal30 Nov 18, 2008
    same problem, resoldered the capacitor and worked fine, until i replaced the cover, same problem again.
    Problem Solver:
  • 4 Answers
Same problem here - I also had a very loose brown capacitor, almost completely coming away from the amp board, so I soldered it back and I haven't had the problem since. I used a good amount of solder too. I also put a spot of solder on the headphone to amp board connections at the board end. As I say, so far, it has been working perfectly. Now I just need to find out how to change the laser unit so I can play SACDs and I should have a fully working unit at last !
Posted on Nov 27, 2008
Hi, i am having the same problem right now, but when
i wiggle the little connector from the headphone on the mainboard it clicks to normal mode, so the connector is loose
and i think thats the whole problem.
i suggest that you resolder(am i spelling it right?)
the connector and it will be fixed.
cheers
willem
Posted on Jul 25, 2008
Turning off
I got a DAV system that had exactly the same problem, ie. it was stuck in "headphone mode", this mode should be active when headphones are attached then it should revert to amplifier mode when the headphones are removed.
I opened the cover and removed the amplifier output board (the one where the speaker wires connect to) and soldered the following dry joints.
1) large brown capacitor on the amp output board.
2) dry joints on the rear headphone socket (the one that has the connecting lead from the front headphone socket)
3) Then one of the surround channels didn't work so I soldered further dry joints on all the coils (white vertical rectangular blocks)
I tested all surround chanels before putting the lid back on (careful, watch the mains) and found all was now working ok.
Mar 11, 2008 | Sony DAV-S500 System
My sony dav dz270 home theatre has no sound through centre and rear speaker
You must have changed the listing mode to stereo.In that mode only the left / right & subwoofer will work. Press the surround button and change it to any other mode .
Mar 14, 2011 | Sony DAV-DZ720 Theater System
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
How can i play my ipod on a dav-dx150 home theatre
there is a wire that pluggs into the headphones spot on our iPod, it then splits into a red/white cable. i dont know where to get this, but mine came with a DVD player
Feb 14, 2009 | Sony DAV-DX150 System
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Nov 14, 2008 | Sony DAV-S400 System
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Sony DAV-S400 System Logo
430 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
