Question about Brother CS-100-T Computerized Sewing Machine
E6 and F5 error message
My daughter tipped over my sewing machine and now when i try to sew it brakes the needle and i get a E6 and a F5 error message
do you think it can be fixed or am I sol
  • Anonymous Mar 29, 2014
    sews fine for a while then locks
    up and gets an e6 error
    Problem Solver:
  • 9 Answers
Are you using the right size needle? Try using an 80. Also try taking it to a service center. To find one near you go here: http://www.brother-usa.com/service/
Posted on Jan 06, 2009
Error message e6. Needle won't move
Check your owner's manual - troubleshooting section. Sometimes it will show the error codes. Otherwise, search the internet for:
Make + Model + "error code E6"
You can also check with the manufacturer.
Nov 09, 2016 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
The sewing maching stops while it is sewing - makes a squeeling sound and has a E6 error message, but I don't see any thread anywhere that could be causing the problem
try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way
try another bobbin
try a new needle-one that is for the fabic being sewed
if none of these suggestions help then it would be a good idea to
have the machine serviced
Jan 07, 2013 | Brother Sewing Machines
How do you clean brother SQ9050
try changing the needle
make sure to use every thread guide this is important for the tension
try using a different bobbin
clean under the needle plate and in the bobbin area for lint
also possible that the machine may need some type of adjustment
or the machine could be starting to have a timing problem
Dec 08, 2012 | Brother Sewing Machines
I have a Brother XR6600 - today I got an E6 error indicting tangled thread. Ihad a check and cleaned it but no thread. When I try to sew the machine jam's ..... Help!
try these things
new needle
rethread machine--presser foot & needle to highest position
keep a check on the thread take up lever, when the top thread come
off the thread take up lever it can also make the machine jam
Jun 05, 2012 | Brother Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
I have a Brother CS-770. My fabric got pulled down into my sewing machine and the thread got tangled and I got an error message E6. I untangled everything, checked my needle to make sure it wasn't bent...
Hi. It's very likely that the needle is inserted wrong. Take the needle out and make sure that the flat shank of the needle is facing away from you (to the rear of the machine).
Try this and let me know if it helps, ok?
Robbie
Aug 10, 2010 | Brother Sewing Machines
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Turn off the power and remove the needle and presser foot.
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
May 19, 2007 | Brother CS-100-T Computerized Sewing...
Brother CS-100-T Computerized Sewing Machine Logo
753 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
