Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
White screen when i turn on my camera the screen is mostly white and then there are like thin black lines coming out from a dark dot in the center. i can still take pictures but i cant see any of them. Is there any way to fix this?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey kih24,
If you can access your menu system at all I would try resetting your camera to the default settings, and instructions on how to do this are on page 31 of your user manual. If you can't access your menu system you can try removing the battery and memory card for a couple of minutes and then reinsert both of them. If this doesn't work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 25, 2008
Gv471 fhdtv10a
help my pliss
Feb 07, 2014 | Televison & Video
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
Get the blue and white lines of my screen
you can go to the service center may be your display is not working properly
Sep 13, 2013 | Fujifilm Finepix Hs30exr black Digital...
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
My Kodak EasyShare M753's screen is white with black lines
That must have been caused by a drop and I'm pretty sure your screen is gone. Try to send it back to Kodak they may not charge you if it's not obviously physical damage, if they refuse to give you warranty service there are third party camera repair places but they will definitely charge you.
Dec 13, 2008 | Kodak Easyshare M753 Digital Camera
Installed new drum
dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Dec 03, 2007 | Sharp AL-1655CS Copier
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
