Speakers I can't get my speakers hooked up with my new dell inspirion 530s. I am using the harman/kardon speakers I had with my dell dimension; when I plug them into the electrical outlet - they let off a very loud hum.
  • Simon Vann
    Simon Vann May 11, 2010
    When these are plugged into the outlet, are they connected to the PC at this time??
    If they are, try unpluggong them from the PC and see if the hum persists.
    Please let me know the outcome.
  • 144 Answers
Hook on speakers to the right jack.
Most of times it is the Green Jack you must plug in the speaker. See for the speaker icon below the jack, that should give you the clue...
Hope this helps...
Posted on Jun 22, 2008
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
Jun 27, 2011 | Harman Kardon HK206 Computer Speakers
Need the AC 15V 1.1a power supply
Hi Tracy,
Wow, this was a hard one. I called both Harman Kardon and Dell, seems HK made the speakers for Dell, but neither company carries parts any more. I called Radio Shack thinking they would have a generic power supply, not even close. I looked at several places on the internet and had no luck.
I do have a little good news, I was able to find a few on Ebay, so if you don't mind buying used, you can get a power supply there. They even have a Buy Now offer so you would not have to bid on it. The power supplies are listed as 1100mA which is the same as 1.1A.
Also, if you get the it and the plug in is not the right size, take the speaker to Radio Shack and they will be able to sell you the correct plug, all you will have to do is splice in the new plug. With it having an AC output, you don't even have to worry about the wires being crossed as you would with DC. Hope this helps you.
Here are the links:
http://cgi.ebay.com/Harman-Kardon-A481511OT-15V-1100mA-Black-AC-Adapter_W0QQitemZ190450725250QQcategoryZ79846QQcmdZViewItem
http://compare.ebay.com/like/370463130288?ltyp=AllFixedPriceItemTypes&_dmd=Gallery&var=sbar&rvr_id=189044360544&crlp=1_263602_304692&UA=L*F%3F&GUID=0234523512d0a0b3f8f79f17ff3c9895&itemid=370463130288&ff4=263602_304692
http://cgi.ebay.com/Harman-Kardon-A481511OT-HK-01T-AC-Adapter-15V-1100mA_W0QQitemZ190450725272QQcategoryZ79846QQcmdZViewItem
Dec 23, 2010 | Harman Kardon HK19.5 Computer Speakers
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
hi,
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
ok
Dec 17, 2010 | Harman Kardon HK206 Computer Speakers
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
No sound coming from my speakers
Hi !!
Cause: Drivers for the sound card are removed.
Here's the link to download the drivers for the Dell Dimension 2350 sound card.
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R56339&SystemID=DIM_PNT_CEL_2350&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=67126
Download the drivers first.
Install the drivers & Restart the machine.
Restart the machine & you are good to go.
Regard'
Anurag Shukla
Sep 07, 2009 | Harman Kardon Audio Players & Recorders
Asending sound
dear sir
it's sound setting given in to sound control panel may be it's set to holl or equalizar is set miss match and chek yr sound pin which connected is proper or not otherwise just put a wizard given in control panel or chek yr sound drviers it;s help u...:)
thanks
please vote
jo_Chinmay
Jan 05, 2009 | Harman Kardon HK695 Computer Speakers
HK206 SPEAKERS WITH USB PLUG
have you plugged anything else in to make sure the usb port is working? does the computer recognize the usb speakers when you plug the usb plug into the computer? do the speakers work on another computer? if you wiggle the usb wires around does it make a sound through the speakers? eliminate these questions so that we can move on to isolating the issue.
Oct 13, 2007 | Harman Kardon HK206 Computer Speakers
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
