Dound distortion on TV
Hi
The Digital TV is where I am getting the sound distortion (hiss) and is connected to the outside aerial socket by a male/female connector (not a cheap one).
Thanks
Jill
  • 3 more comments
  • cassox Jun 21, 2008
    Hi
    Is is coaxial white. The TV is a Wharefdale L19T11W_C 19 in HD Ready Digital LCD TV/DVD Combi.
    Thanks
  • cassox Jun 22, 2008
    Hi
    The freeview is integrated within the TV not via a digibox. The connection is to a standard rooftop aerial,not via a tv company.
    Thanks
    Cassox
  • Lee A.
    Lee A. May 11, 2010
    Have you tried a different coaxial cable?
  • Lee A.
    Lee A. May 11, 2010
    Do you have a digital reciever box? or do you get your cable straight from the wall? If so who is you TV company?
    Keep me updated,
    Thanks,
    Lee
  • Lee A.
    Lee A. May 11, 2010
    what kind of connection is this? Do you have a digital tv reciever? Is it coaxial? composite(red,yellow, white) What is the exact make/model of the tv. Is there another audio connection you can try your dtv with?
    Thanks,
    Lee
  • 4,472 Answers
Hoping to hear back from you. Have you tried a different coaxial cable?
Thanks,
lee
Posted on Jul 08, 2008
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Can I hook up a copying device to my LG 26LV2500
Such as a DVD recorder?
Yes, conventionally a recorder takes the feed from aerial or box befiore the TV but recording whatever you're watching can also be done mostly by using one of the Scart sockets usually on the back of a TV usually identified as Scart 1 AV in/out which should be connected to Scart In on a recorder.
If there are digital output sockets - and digital input sockets on a recorder - you'll get higher image and sound quality than you'll get from Scart.
Sep 23, 2011 | LG 26 26LV2500 26 LCD TV
Put the radio in my truck about 4 months ago, worked great. the truck sat for months because it was broke, now i get it fixed, put the face on my radio and everything is on, my radio, my amp is running but...
Turn the volume up to the highest level.
Can you hear a hiss or static?
NO...usually means speakers are disconnected..often loose socket at rear of radio or broken wiring
YES...Hiss means either blown speaker, faulty radio or faulty aerial.
If you have tape or CD as well , this will prove whether it is the aerial or not.
HISS with CD or tape playing means faulty radio or speakers
WORKING OK with CD or tape means faulty aerial
Feb 20, 2011 | Car Audio & Video
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not...
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
How do you connect a toshiba dvd to a tlc plasma tv
First of all unplug tv and tosh dvd.
1.connect the antenna(digital aerial) to the ATENNA IN jack of the dvd.
2.connect the ANTENNA OUT jack of the dvd to the Aerial jack of your TV.Using a RF cable(usually supplied if new)
3.Connect AV1(TV) scart socket of the dvd to the scart socket of your tv.Using a scart cable.
Then you are ready to start and program the channels.
Oct 10, 2009 | Televison & Video
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Do not understand how to set up my alba digi box to my television and recieve basic digital channels help!
Hi.
Ok
1) plug aerial in to the antena in sock on freeview box.
2) plug short aerial type lead in to rf out socket on freeview & antena in socket on TV.
3) plug A scart lead in to the socket marked TV on freeview box & the other end of scart in to one of the scart sockets on the TV.
If your TV has more than one socket plug it into the one marked AV1 or AV2.
4) plug in freeview to mains electricity & switch box on.
5) Turn TV on freeview should appear automatically if it doesnt look on your TV remote for A button marked AV or a button with either A circle or square with an arrow going through it you may need to press this several times until you see digi picture come up.
Thats basically it but do check that you dont need a new aerial etc to be able to get digi signal in your area.
http://dysonmanuals.llc.nu/
Jul 26, 2008 | Televison & Video
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
