FixYa.com
Tags:
Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher
posted by jlsmtripp on Jun 21, 2008
The clean light is flashing and the machine will not start.
Comment by jlsmtripp, posted on Jun 22, 2008
Thank you so much!!!! It worked!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
reg501
Rank:Guru Guru
Rating: 90%, 222 votes
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
whirlpool dishwasher quiet #1
I have a white plastic tube ab... Answer This...
Whirlpool Quiet Partner II...
The locked light remains on. I... Answer This...
Whirlpool Dishwasher
had to replace the discharge... Answer This...
Whirlpool Gold Quiet Wash Plus...
After 3 days without power due... Answer This...
Dishwasher problem
Hi My dishwasher will fill with... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
