Question about Kenwood Car Audio & Video
I recently bought a 1994 Camaro with a Kenwood KRC 953 stereo in it. The radio display is working but no sound at all is coming out of the speakers. What is the problem?
    President:
  • 624 Answers
Yo most likely have a bad speaker or the amplifier IC inside the radio is bad. More often than not, it is the amp IC.
first double check that you have all speakers connected right and that you don't have a speaker wire that may have an exposed area that could be shorting against the car chassis.
You can check the speakers by disconnecting them one at a time and see if the sound returns to the remaining speakers that are still connected. After checking one speaker, re-connect it and try another.
If the sound returns after dis-connecting one speaker, that speaker is your problem.
If none of this helps, you will need to get it serviced. If you are skilled with soldering and can dis-assemble and then properly re-assemble a radio, this is a very easy fix and I can look up the part number for you of the amp IC. it is also right on the IC itself. If the amp IC is blown up badly, you will see burn markes on it and sometimes a piece of it can be blown right off of it. In that case you will not be able to read the part number.
Normal repair cost for this type of a problem run between $80 and $120 at most shops, depending on the shops rates.
This is a very high end cassette player and in it's day cost about $400 back in 1997 when it came out. But todays car stereos are nearly as good built, and cost much less.
You can get a good car stereo with CD for about $150, cheap ones for $100.
Let me know if you need any further help, and if you found that this information was helpful a good rating would really be appreciated.
Thanks and have a great day,
Dave
Posted on Jun 21, 2008
Kenwood car stereo (DX503) reads Ipod information, but suddenly there is no volume (song name's and artist stream as usual, but there is no sound)
Check your connection from Ipod and the car stereo it might lose or borrow connector wire or bluetooth ( if your using it ) to check the apparatus if its work or check it to the other car stereo with the same model. Check the format requirements of the ipod and car stereo. If this can read Mp3 or Mp4 or any format as it was before. Is your radio and cd player have sound when you play it. If not your Amplifier is not working.
Sep 10, 2011 | Kenwood Car Audio & Video
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
Kenwood car stereo no sound at all, it's got power and works on another car, the system is fitted in a Peugeot car. When system turned on get little crackle out of one speaker please help.
i had a kenwood before they are not bad at all . if ur cd player works in another car ,like the sound comes out an every thing then its got to be the wiring i the car . then u buy wiring wipe an u got to wire them yourself it could be a pan . if the old radio worked before u took it out of the car i would try the wiring ..
Feb 25, 2011 | Kenwood Car Audio & Video
My stereo says" protect" everytime i turn it on. can't get anything else.
Hello grammagrisbo, hi your Kenwood head units will show "protect" when there's a problem with the speaker outputs so check to see if the impedance load meets your radio, 8ohms or 4 ohms?. having parallel two speakers on a single channel may cause this dilemma. This might also mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back to normal, the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do something to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. power it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker only. Turn it on again and see if it will displays "protect" message.
If the radio works with one speaker connected, connect the other speaker to the second channel, you may have now the idea where the problem begun, you will identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that channel.
If it displays "protect" with a single speaker connected, then disconnect that one and try the other one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit.
Aug 31, 2010 | Kenwood Car Audio & Video
No sound from radio, display works, speakers work, wires correct
do you have an amp hooked up to your car stereo ?
Apr 25, 2009 | Car Audio & Video
I have a KRC 585 car audio unit. Power getting to player but it will not switch on.
Try finding a solid ground and make sure theres not only a hot lead but also an ignition lead. If that doesn't work, you might have to a stereo shop look at it. Wait until best buy offers a coupon, usually every 4 months.
Aug 07, 2008 | Kenwood Car Audio & Video
I have bought a kenwood kdc-241 car stereo i have downloaded my mp3 s onto cd-r (about 60 of them)when i put it into car stereo they play but no sound comes from the system (the radio sound is working also...
Hi i have just looked up your stereo and that kenwood doesnt support mp3 playback.
Unlucky mate.
In order to play a cd like that the head unit must support mp3 playback
May 30, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
