Question about HP DeskJet 6540 InkJet Printer
Hp deskjet 6540 carriage out of alignment
My printer suddenly prints as if it is out of alignment and get stuck on the left side and sometimes the gears scrape.
    Novelist:
    Scholar:
  • 70 Answers
Probably a small piece of paper (now black with ink and hard to see) stuck in the extreme corners (probably the left side).
Posted on Jun 21, 2008
  • Kim Parker
    Kim Parker Jun 22, 2008
    This printer "caps" the cartridge after a 2 hour idle. A cartridge that is leaking just a very small amount out of one of the tiny nozzles can have wet ink on the nozzle when it is capped. It is supposed to wipe the ink off before it caps it but if there is more than usual and the wiping is not long enough to remove it then the cap may stick and ever so slightly move the nozzle "foot" or plate causing misalignment. The sticking may also be related to a leaky cartridge? Remove the cartridges and check for excessive (any) ink on the foot (nozzle plate). You might also touch the edge to see if the foot is loose.
    You probably have already done this...is the printer still out of alignment when you put new cartridges in? If so then it may be a blockage of the scanner that checks the alignment. No user fixable parts here.
    And I'm sure you ran the "Align Cartridges" under "Printer Services"...right? This is automatically run each time you put in a new cartridge. It is not done just by removing the old cartridge and putting it back in. Each cartridge has a serial number today and that serial number is recorded in the printer's memory so that it does not waste ink by priming each time a cartridge is removed and then reinserted. Let me know...good luck.
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
My HP Deskjet 6540 doesn't print the test page or anything else.
How do I print a test page without the printer being hooked up to a printer ?
Feb 08, 2011 | HP DeskJet 6540 InkJet Printer
My hp deskjet 6540 prints ok at first but then halfway down the page the black turns brown, then red!
Please check your ink cartridge. If it is old change it. Also clean the nozzles. After doing this print the test page.
Jan 14, 2011 | HP DeskJet 6540 InkJet Printer
I have an HP Deskjet 6540. What do the two orange lights near the on/off switch incicate?
The HP Deskjet 6540 series printer has two print cartridge status lights. The left light corresponds to the left print cartridge, and the right light corresponds to the right print cartridge.
Jan 08, 2011 | HP DeskJet 6540 InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Use Printer Offline: Error Processing Command
    Go to system settings and select the 'Printer' option.
    Right-click on the printer and enable the 'Use Printer Online' function.
    Cancel all the printing jobs till that moment and redo the process.
    Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
    Check all network connections and functions.
    Be sure the network interfaces work properly.
    Turn the printer off and on to see whether the device is working properly.
    Jun 07, 2010 | HP DeskJet 6540 InkJet Printer
    Printing is off center on the HP 6540. The image or page being printed is cut off on the right margin and on the bottem of the page.
    ok, most likely your printer cartridges are off. In order to fix this, you can use windows to align them. Click start > Control Panel > Printers and Faxes, and right click the printer thats giving you trouble. Then go to properties. Next, go to the services tab, and click align the cartridges, and continue from there.
    Sep 01, 2009 | HP DeskJet 6540 InkJet Printer
    HP Deskjet 6540 Alignment
    Yeah, the only thing that can cause this is paper feed problems.
    There must be either something loose in the paper feed mech (look for wobbling "tires") or there is still some paper or other foreign debris in the paper feed path.
    Jul 03, 2008 | HP DeskJet 6540 InkJet Printer
    HP DESKJET 6540
    from Windows Desktop, click Start, settings, printers, locate and right click on the icon for your printer. Go to Properties, Advanced, then print processor, make sure that the options WinPrint, and Raw are selected, then click ok back out, try printing again.
    Daniel (rydf)
    Apr 30, 2008 | HP DeskJet 6540 InkJet Printer
    HP Deskjet 6540
    The color cartridge sping was loose. I am in the process of super gluing it into place. Hopefully it will work.
    Mar 19, 2008 | HP DeskJet 6540 InkJet Printer
    HP DeskJet 6540 InkJet Printer Logo
    390 people viewed this question
    Seeker5211
    Seeker5211
