Question about Archos Gmini XS 100 MP3 Player
The power randomly shuts off, will not stay on
My Gmini 120 randomly shuts off in the middle of use. It has been dropped and I noticed the casing is secured as tightly as it should be.. Would that cause this problem?
  • dovber26 Jun 21, 2008
    I meant the casing is not secured as well as it should be?
  • ArchosAddict Dec 19, 2008
    My Archos won't charge up, won't stay on for very long, and sometimes won't turn on at all.
    Help me? Mine has also been dropped and my casing is also the tiniest bit loose.
I think squeezing the casing back together works... it did with mine. For a while anyway, I have yet to see if it lasts.
Posted on Dec 19, 2008
Dell Vostro 230 shuts down randomly
maybe it's a motherboard problem
Dec 04, 2012 | Dell Vostro 230 Notebook
Sony VAIO VGNNW240F randomly powers off
The Operating system maybe corrupted but your files are still good. Try to run a system restore and before the date you notice the system fails to start.
Dec 08, 2017 | Sony VAIO VGNNW240F Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Pc keeps randomly powering off & then back on. Won't stop until I unplug it.Holding down power button won't shut it off. On occasion it will stay on - is able to boot & be used normally while it...
Power supplies usually are culprits in random shut downs, but random start ups is a bit more complicated. You say that when you hold the power button, the computer won't power down. Perhaps you have a faulty switch? Make sure your PW switch cable is securely attached to the motherboard. But I'm leaning more toward a faulty switch or a short in the wires. Seems like a good place to start.
Sep 05, 2009 | E-Machines eMachines Desktop PC
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
Phone doesn't turn on, randomly shuts off
This same problem hapnd 2 my fne i bet the smaller screen at the front dosent work either well the problem is the wire connecting from the screen to the main part isloose try tightening it,if this does not work squeeze the screen/middle part conecting the two
Aug 24, 2008 | Motorola Mobility RAZR V3
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Gmini XS 202s wont turn on properly....
I heard of that problem, it could be your charger circuit and it could be your battery. There's a interesting forum post on this at www.newmp3technology.com: http://www.newmp3technology.com/forum/viewtopic.php?t=700
But here's something else: I'll buy your xs202s if you want.. :)
For a reasonable defect-price.
I have one but the display is broken.
Had no luck trying to find that obscure 2" 128x128 backlit greyscale korean display in the IC-market here in Europe.
Sep 28, 2007 | Archos Gmini XS 202s (20 GB) MP3 Player
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
May 22, 2007 | Archos Gmini 402 Digital Media Player
Archos Gmini XS 100 MP3 Player Logo
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
