For hydraulic brake systems, there is a little rubber seal on the plunger attached to the lever. This is part of the lever/reservior assembly. An older bike like this may be fixed cheaply by changing it. If your reservior level is low, then it could simply be needing fluid. first try bleeding the brake lines of air. If that does not do it, then check bikebandit.com for the plunger.
