My computer is slow and its visual is poor - Computers & Internet
  • Mulch Aug 21, 2008
    Computer is extremely slow, cannot watch movies anymore due to erratic screen play stopping and starting with audio continually running and scrolling on web pages it has a line and then catches up slows down has a line and catches up and on start up the screen starts dim and scrolls like a powerpoint to bright. Fresh install of XP problems before and after format.
Brust your computer
Posted on Jun 22, 2008
Hi my pc and labtop is very poor so wy cant i do
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program. To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Feb 07, 2014 | Computers & Internet
Computer running slow
right click on my computer
click properties
click on advanced tab
go to performance then advanced
then visual effects
then adjus for best performance
then ok
and download tuneup utilities 2012
Jun 26, 2012 | HP Compaq Presario SR1020T (PU167AV) PC...
Videos load slow
hmm three options
internet connection speed(check that)
memory usage(how much on board)
windows using too much memory
start button
control panel
system icon
advanced (last on list on upper left)
visual performance
check 'for best performance' and apply
might need to restart computer
Jun 03, 2012 | HEWLETT-PACKARD Pavillion DM1-3020US...
2005 saturn vue 2.2L What is code B3BFF ???? Cooling fan keeps running
Means--Blower Motor Relay Control Circuit Low or High....
Visually inspect the relay and connection for damage.
Visually inspect the instrument panel fuse block for damage.
Check for poor connection at the BCM (Body Control Module).
Jul 21, 2011 | Saturn Vue Cars & Trucks
Computer too slow to play song
Computer memory and processor speed are the things that make a computer too slow for music playback. Also check your system for routine maintenance. Use the Computer Cleanup utility in Windows. Although this will help, the system may not have enough memory or processor speed to playback.
Jul 31, 2010 | Propellerhead Reason 4.0 Upgrade - Windows...
How to change windows 2000 to the new one?
to make your computer fast follow these steps
1. remove all files from %temp%
2. remove all files from prefetch
3. right click on my computer
4. click properties
5. select very first option where it says Performance
6. uncheck all visual effects
7. click apply
8. select advance
9. select virtual memory
10. set virtual memory to recommended
11. click apply
12. click OK
13. restart your computer
and less visual effect you use more faster your pc will be as visual effects consume lots of memory. Download Malware Bytes from
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
and follow instructions to install
run malware bytes to remove trojans, broken registry entries.
restart computer
May 04, 2010 | Compaq Presario Notebook
When I swith on the computer,sometimes it can't open,thesystem can run but no visuals.the moniter shows orange light.it is very slow also.
the video (visuals) issue could be a video driver issue.
assuming that you do get something on the screen when you turn the computer on, try to to start your computer in safemode by pressing f8 severval times after you get the first screen, you should see advance startup options. select safe mode and attempt to install an updated video driver (which one depends on your video card manufacturer and model number).
if you don't get any video at all you video card may need to be replaced.
slowness
this is cause by memory wear out or (most likely) malware, now.. you need video and you need to be able to boot into your computer to run some tools that would clean up your system. slowness could also be caused by an old hard drive, if this is the case is better to first get all your data out into a removable hard drive, and replace the hard drive and resintall the operating system.
post back if you were able to get boot up if you have further questions.
Apr 23, 2010 | Intel Computers & Internet
After installing Windows 7, my SamSung SyncMaster 2233BW has very poor picture. Regards.
Yes,Because Windows 7 is taking the higher amount of Ram.So the videos will be very poor and also system will be slow down.You must increase your Ram to 1 GB. (or) Use windows xp.
Thank u...
Feb 13, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
My computer is really slow going into differnt sites....the compressor fan is slow to start up...had my computer stripped down and tuned up, but it's still slow...they said the cpu is showing its age,...
Your computer going slow could be for the following reasons: 1 Not enough RAM - remove unwanted files by cleaning the disc. Also defragment the computer. Increase the RAM 2 Virus - remove the virus 3 If you do the above you will see the improvement and no need to have a new cpu
Dec 22, 2009 | Computers & Internet
Computer slow
Download RegscrubXP program and run it.
This can clean a lot of rubbish from your registry that makes the computer go slow.....
Jul 10, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
309 people viewed this question
David Payne
David Payne
