Question about GE 3.2 Cu. Ft. Super Capacity Washer
Maytag LAT8240 leaking water
I have a Maytag LAT8240 washer that has been grate for over ten years. I don't think anybody makes them like this anymore. It is leaking water now and they tell me it will be cheaper to buy a new one than to repair this one. How much should it cost to repair it? Is it worth getting a quote? Or do I really need to go shopping for a new one?
Thanks so much in advance for your help....
Irene Owen
  • Kevin Emmel May 11, 2010
    It depends on where it's leaking water from? There are many sources of water leaks, some are inexpensive repairs, others are very expensive, and therefore may exceed the value of the washer. I would recommend that you at least get an estimate of repairs before giving up on it, if you are happy with it otherwise.
  • 234 Answers
Irene, I would get a quote on replacing the tub seal. There is a kit that costs about $75.00 and that is probably the problem. These are good machines and I just replaced the same part in our maytag recently.
The locking collar on the hub is left hand thread. This may help with the replacement.
Posted on Apr 27, 2009
Washer wouldn't stop filling and leaks
Hello, here is a great link to check out everything you can think of on your washer repair and trouble shooting. Make sure you really check out the different areas to click on on this site..
Here is the link. I hope this helps you, mike
Oct 20, 2011 | Whirlpool LCR5232H Top Load Washer
I have a maytag model A312 washer that has worked fine for almost 30 years. Wash cycle works with water pouring in but the barrel will not spin. I cannot even force it to spin around. Any suggestions...
Hello, Awesome Maytag washing machine. Sound like that wonderful Maytag transmission has finally gone to transmission retirement center. I think they might have rebuilt transmission for your Maytag washing machine. Check with your local Appliance Repair Shop---Maytag---. Ask them if they have a transmission but I am thinking here, it could be belt driven. If it is belt driven, empty the washing machine and be careful when turn over your washing machine. There is two concrete block that hangs on a self leveler to keep you washing balanced during the spin cycle.
Also, check for oil under your washing machine and if there oil then your washing machine has a transmission and it is leaking. Well, Tracy you can try the few thing that I mentioned here. But remember I am only suggesting you try these thing and if you don't fell like you can't handle it. Then get your neighbors and friends to help you, please. GB...stewbison
Sep 07, 2011 | Maytag Washing Machines
Leaking drum on maytag washer.
Go to and enter MAV6000. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and replacement.
May 23, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
My Maytag MAH7500Aww leaks water on the rinse cycle?
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Leaking maytag
it could be the pump but there is a seal in the tube where the transmissin goes through the tub that seal has a common problem of leaking but if it 10 years old i would replace the machine
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer repair
It was manufactured in May 1993. However, depending on the problem, you may seriously consider a repair. The reason I say this is because this is a GOOD Maytag, before they started going downhill, and will probably last another 10 or more years. If you consider fixing it, post the actual problem it's having and I'll let you know what I think.
Apr 04, 2008 | Washing Machines
Maytag LAT8240
you can cll the manufacture and with the pruduct serial number they can determine age
(866) 616-2601 U.S.
(800) 688-2002 Canada
Washing Machines Logo
95 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
