Question about Mitsubishi CS-40507 40" TV
Sound disappears after something inside the tv makes a mechanical clicking sound. It comes back on randomly, then "click, click, click, click" it's off again. Great tv otherwise! Please help!
  • jperson Aug 07, 2008
    The sound on my TV went out. There is a picture but no sound. The TV is hooked to a satellite.
  • VPOOKYDO Nov 11, 2008
    the sound goes off and on. it also makes a clicking sound. sometimes the sound stays off 5 min. sometime 30 min. really random.
    Genius:
  • Mitsubishi Master
  • 1,550 Answers
Maybe the audio amplifier IC of the tv are damaged
Posted on Jun 22, 2008
LG TV 47 INCH MODEL-47LA6200 THE TV RANDOMLY MAKES A SNAPPING SOUND, THEN THE TV TURNS OFF, AND COMES BACK ON IN ABOUT 10 SECONDS AND IT WORKS AGAIN,
Sounds like something inside is arcing. I would get a good strong vacuum and vacuum the guts out and also move some of the high voltage parts around away from other parts and then see what happens.
Apr 24, 2017 | LG Televison & Video
Toyota corolla problems
I'm no mechanic but sounds like either a wheel bearing is going or gone, or could be your universal joint going on that side. not something to let go if it is either, as it could break and drop the car to the ground. please have it checked...soon!
May 12, 2014 | 1999 Toyota Corolla
Put television on then goes off by itselfs and comes back on makes a we clicking noise off comes back on about three minutes
have the power supply looked at--the clicking sound is most likely the power relay (mechanical) coming on and then off again.
Nov 03, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Clicking sound when power is off
have the power supply tested or use a diff power supply in your cpu, just to see if the clicking sound will disappear,if it disappear then a power supply replacement would be beneficial, if not then have your cpu check by a qualified tech to see where is that sound coming from
Nov 21, 2009 | Gateway Bestec ATX-300-12EB3 305w Power...
HL-R4266W shuts down and a faint clicking sound can be heard
I believe I read somewhere that when you open the back cover over the lamp, there is a special little black switch that needs to be in the up position when you put the cover back on, or the TV can shut itself off randomly.
Aug 16, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Clicking sound from VCR area
there is a infra red LED inside the unit that fails. this LED sends infra red signals to 3 other sensors for load and stop and counter. when this LED fails the mechanism thinks you are loading a tape. have a tech replace this LED.
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
Rca p46771at won't come on post lighting.
Have you tryed to unplug for a while and plugging back in again.. Ff that dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Jul 25, 2006 | RCA P46924 46" Rear Projection Television
Have you tryed to unplug for a whiloe and plugging back in again.. if tha6t dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Televison & Video Logo
192 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
