Question about QuietLine WD-9900 Front Load Washer / Dryer
Dryer does not cool down and clothes are "very hot" to touch when cycle has completed. We changed out the cycling thermostat but that does not seem to be the problem. Any suggestions?
  • countrykim Jun 30, 2008
    The cycling thermostat was replaced but this does not seem to solve the problem. Should the heating element come on when dryer is on "air fluff". Mine does. Is this normal? All vents are clean, no lint or debris. Dryer is not that old..less than 1 year old. Do I need to replace other thermostats too? I would appreciate any help. Thanks
    Novelist:
    Scholar:
  • 70 Answers
1. clean the inside of the door (behind the holes). Watch your hands, the holes are usually very sharp.
2. clean the exhaust pipe (with the crevice tool of a vaccuum) below the screen.
3. remove the hose to the outside exhaust vent. Take it outside and clean it out or buy a new one.
4. clean out the exhast vent to the house or buy a new one.
5. replace all of the thermostats (two or three)
There is a device on top of EVERY drier output or exhaust pipe INSIDE the machine that measures the heat. There are usually two and sometimes three. Each of these devices (thermocouples) job is to shut down when the temperature reaches a certain value. The first one is usually inside the door and measures the temperature which is sent to the computer, compared against the temperature setting you gave it "cool, warm or hot" and regulates the heaters accordingly. When this is working properly then there is no need to have any of the other ones. However, the others are there because dryers are very dirty devices and often fill the air outlets with "fuzz". The fuzz then insulates the thermostat so that it can't measure the correct temperature. The other one or two are emergencies to make sure you don't have a fire. I've seen dryers where all of these devices have burnt up. You can't measure whether they are working or not without a controlled heat source and a working temperature probe. Just count on replacing them.
Posted on Jun 21, 2008
    Genius:
  • 1,036 Answers
Check all vents and clean the filters.
There should be a blower fan inside that circulates the air when the heating element is on.
If the fan is not circulating the air properly, the heat will build up.
There is also a problem of accumulation of lint in the air ducts.
This should be removed.
There are numerous occurances of similar problems to yours resulting in fires, due to excess heat and lint build up.
PLEASE be aware of the safety issue in resolving this.
Thanks.
The dryer on my machine doesn't go through a cooling down cycle, therefore leaves everything very creased.Does the dryer have a cooling down cycle? The clothes come out of the dryer burning hot.
I would check the cycling thermostat and hi limit thermostat as they regulate heat. the cooling cycle should come on at end of cycle as the thermostat detects the dryness of the clothes. also may want to check the moister sensor inside the drum usually on the door, they look like 2 aluminum strips.
Mar 01, 2015 | Washing Machines
I have a frigidaire gallery series dryer that will run on low heat setting just fine but when I set it on medium or higher it shuts off after a minute or so. ..I replaced the thermistor but it didn't help....
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Nov 04, 2014 | Dryers
GE dde 5300 dryer overheats.
You need to replace the "cycling thermostat" on your unit. Here is the part to order.
The thermostat is located at the back of the drum on top of the heater assembly.
Nov 24, 2012 | Dryers
Dryer gets hot and turns off
Hello there:
A lot of the times the problem lies with in the Cycling thermostat that is going out Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly.and can make the dryer stop working after it is working for a given amount of time If so, you need to replace it.
Next is the The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
It overheats and shuts down due to a bad thermostate Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Sep 27, 2010 | Kitchen Ranges
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
Aug 05, 2009 | Dryers
I have a Frigidaire Dryer model GLER331AS1 and one day it was all lite up with heat I had to manually turn it off, after that it will run but it wont turn off if it's not on the minutes drying time it just...
hi Gwen. I can help you.
Jun 08, 2009 | Dryers
Dryer will not turn off
May 20, 2009 | Dryers
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
QuietLine WD-9900 Front Load Washer / Dryer Logo
176 people viewed this question
Top QuietLine Washing Machines Experts
Are you a QuietLine Washing Machine Expert? Answer questions, earn points and help others
