Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water and ice won't dispense, temperature control flashes
When you hold down the lever for water or ice, nothing comes out and it makes a soft clicking noise and the temperature control starts flashing 0.
  • Anonymous Jun 24, 2008
    No water or ice through dood. Lights on the dispenser work. When disperser is depressed, lights on dispensed go off and temperature indicators and control LEDs inside fridge go out.
  • 54 Answers
You need a new computer board
Posted on Jul 03, 2008
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Ice won't come out
if it's making ice, but the ice won't come out, it is likely going to be the dispenser motor (found behind the ice bucket).
the other possibility is the lever where you put the cup could not be hitting the switch, but most likely it is the dispenser motor.
May 21, 2012 | GE Mwf Ge Refrigerator Smart Water Filter...
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
GENE
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Sep 24, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
190 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
