Question about Mintek MDP-1760 Portable DVD Player
Won't play The white strip that was attached to the disc tray is broke. When we load a disc is shows "NO DSC" Nothing will play. The system is only about a year old. What should I do
  • aholloway Jul 21, 2008
    I have the same problem with the RF 251 have you been able to find a solution? Andy
  • 3 Answers
I have the same player with a similar problem, though the cable is not broken on mine as far as I can tell.
When I put in a disc and close the lid, I can hear the disc spin and the drive seek, but after about 30 seconds, it always shows "NO DISC" in the upper-left area of the screen. I used to use it daily to listen to MP3 audio books on my 45-minute-long drive to and from work every day and I'd occasionally watch DVDs at lunch, but now it does not read any type of disc at all.
After I did a Google search, it seems that Mintek's products are pretty crappy overall and the worst part is that Mintek now appears to be out of business. Their web site, www.mintekdigital.com is now completely gone and there is no current contact information.
It's too bad because I really did like the player's capabilities and relatively long battery life. It came with a remote, a wall charger, a car charger, (cheap) headphones, and a video out to composite video cable. Before I used it on my drive, my son used it in his room because we didn't have a second DVD player and it worked great for him then too.
Posted on Jun 24, 2008
  • Odeon Jun 24, 2008
    Update: I took my player's bottom cover off to see what was happening. The motor I was hearing previously was actually the laser movement motor and not the spindle motor. It turns out that the reason the player does not read any discs is because they are not turning, therefore the laser is unable to read the data.
    I tried doing a somewhat extensive search for the same spindle motor and was only able to find another person looking for the same one, but with no helpful responses. Just in case this helps anyone, it is a Supreming RF-251 motor. I was unable to find any suppliers on Google, with either Web or Shopping pages, so I guess I'm down to either buying a whole new unit or trying to find a suitable replacement motor.
Help!!!!
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
Jun 04, 2013 | Audio Players & Recorders
Philips cdr778 play side door
remove cover and disassemble the tray carefully, and see if it can be put back together/ reset in the tracks. Hope fully nothing is broke and your back and runnin.
Nov 13, 2007 | Philips CDR778 2-Disc CD Recorder
RCA RS2664 Stereo wont play CD in any of the trays but seems to try to scan to play.
Hello
The laser pickup unit's lens may be dirty or dusty. Just put a lens cleaning disc into the tray, and play it at least three times, by ejecting the disc each time, and reinsert in in to. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. If it dose not help you, the laser pickup unit of your RCA device should be replaced with same type and number. OK.
Jan 25, 2012 | RCA RS2664 Shelf System
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
Hi,I have had this Pioneer CDX FM67 mounted on my bike for 5 yrs and it always played good and showed no problems.This year every time I load some cds in the player nothing happens and then I get an error...
It relates to the failure of the loading section. So check on the linking wires/flexible strip to the load motor- this is a ccommon fault and is seen most of the time.
Secondly the tray with CD can get strck due to a faulty disc- being warped. if so manually retrieve and reset.
finally there is a tiny hole near to the eject which can reset the changer if this has hung up or is jammed.
Open the covers and probe.
Jul 17, 2011 | Pioneer CDX-FM687 6-Disc CD Changer
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
DVD problem
Hello Everyone,
All you have are common problems anywhere. Make sure DVD discs are not pirated or not digitally copied. Most players like DVDs are quite sensitive. Most likely, laser lens are dirty or covered with dust. The best way to eliminate the problem is to clean your lens by using disc cleaner available in the market somehow. Drop a small amount of solution on the little brush adhered at the disc itself, load the disc into the tray, like a normal you play and push the botton PLAY , Some cleaner has an audio or video , so that you will be know the operation or further instructions.
Hope this will help solve the problem... Good luck.
REgrds,
Eriez
Mar 26, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Cd player shuffles through all discs, but won't play
contact Durabrand at 1-800-252-6123 or Venturer Electronic
203 Eggert Rd,Bufflao New York 14215-0248
Dec 23, 2007 | Durabrand W600 Shelf System
Mintek MDP-1760 Portable DVD Player Logo
95 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
