Need diagnostic test for Kenmore Elite Oasis HE top load washer it is making beeping noises and has a mind of its own
  • 2 more comments
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    If the washer just randomly beeps and has erratic display readings, this is a known problem with the interface control board behind the operator panel. Can you please verify your symptoms for me? Please post your COMPLETE model number as well.
  • tam hoang Sep 19, 2012
    110-27086204 no display readings at all, have power, if you pull out door lock you will see display readings, but when you try to push any button will go off nothing display
  • tam hoang Sep 21, 2012
    i did replace another circust board, after check evry thing i plug electrical in hear peeb and than not thing happen fist i replace door switch machine work for 5 minute then beep stop work no light at all, i replace new control board don't work help help help , if i can see the diagnostic i may check out but i can not see at all .but if i pull out the door switch off circuit board light will come on tell me that DU and red light at panel. when i touch any button light will go off and will turn on after minute, if i plug door switch back in no light no working nothing.
  • Anonymous Mar 31, 2014
    Uneven load
    Genius:
  • 1,028 Answers
Pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Posted on Jun 22, 2008
    i did but still no light come up any button no sound beep
I have an elite kenmore oasisl washer with an LD code. It is full of water and won't start on any cycle Modle #110.27082604 Type 580 It beepswhen the panel is lit. Help Please!
Posted on Mar 19, 2009
Kenmore elite 580 has f32 code
Posted on Jun 05, 2009
Kenmore elite oasis washer makes noise and unbalanced
If your washer start going to high speed and it make unbalance and bangin on the frame. there was a stator may need replace....good luck
Nov 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
110.27042600 washer beeps repeatedly error code f 2 do you know what i need to do to correct problem with washer does the diagnostic test just fine ?
he F2 error code indicates a user interface keypad failure, this could also be the reason why your washer is running on its own. Something like this will require accessing the controls & checking the harness connections for the keypad. I have included some testing information in the image below.
If you decide to perform the diagnosis yourself please unplug the unit prior to servicing.
Dec 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Makes a rattling noise inside like coins are stuck in it. Does this on the last spin cycle. Never find any money inside the drum though?
Having some trouble using this webiste. I have the exact same problem with my Kenmore Oasis top-load washer. Were you able to find a solution?
Dec 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
3,038 people viewed this question
Top Washing Machines Experts
