FixYa.com
Tags:
RCA RT2280 System
Presets stopped working
posted by sound2280 on Jun 21, 2008
Preset function doesn't set the presets, and the tuner doesn't stop on powerful stations. It remains set on various, seemingly random FM and Am stations.
When you click the stations manually to a good station, it sounds great. All other functions seem ok, though I haven't gone through very many functions.
Comment by sound2280, posted on Jun 23, 2008
Thanks Tech48.
I happen to have been in elecronics a long time too, and I understand what you're saying.
When I get a chance, I'll see if cold solder joints are the problem.
The unit had been unplugged for a couple of days, so that isn't the likely problem, but I might try again just to make sure.
I appreciate the thoughtful explanation.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 22, 2008
Helpful (85)
tech48
Rank:Guru Guru
Rating: 92%, 167 votes
I have repaired a few of these receivers in the past few years and have found several with microprocessor issues and some with a lot of heat stressed solder connections on the main amplifiers board around the voltage regulators.
The problem you are having is similar to problems the others I have repaired were having.
There is nothing you can, as an end user, do beyond a hard reset of the microprocessor by unplugging the unit from the wall and wait about an hour or 2 before you plug it back in.
By resetting the microprocessor you can at least see if the problem is a minor one or not. most likely it is an electronic problem that will take some good troubleshooting skills.
The bigger problem you face with this particular unit is that RCA no longer supplies parts for the audio equipment they sell.
Once the supply of what they have in stock is gone, thats it, no more parts at all for RCA audio. That supply has not been replenished in around a year.
All of the RCA audio equipment sold now is exchange only if it is under warranty.
I know this because I work at an authorized RCA repair center and I am the audio tech. I have not repaired an RCA audio unit under warranty in about a year because of that.
I have fixed 3 or 4 of the same unit you have, but not under warranty.
If you or somebody you know has very good soldering skills you can try reflowing the solder connections on the main board and even reflowing the microprocessor. It could solve your problem, but not advisable unless you are very good with a soldering iron and have done this sort of thing before.
I am sorry for this rather bad news, but it is true. I have been repairing audio equipment for over 17 years and am very familiar with RCA products.
If I can be of any further help please let me know.
Rating Locked! (?) sound2280 has rated this solution as Helpful
Can you Help with these Home Theater Systems problems?
RCA RT2280 System
no sound
Iv had this surround sound for... Answer This...
RCA RT2280 System
TV died slowly
My ProScan died slowly. If I... Answer This...
RCA RT2280 System
no sound from my rca rt 2280
after being subjected to low or... Answer This...
RCA RT2280 System
direct tv remote code for...
We lost the remote for the RCA... Answer This...
RCA RT2280 System
RCA RT2280 surround sound mode...
I have my dvd player (this... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
