Question about Fuji FinePix F700 Digital Camera
Black screen when camera is on
I can view pics from memory disc....but viewer is black when moved to mode to take pic.
    Problem Solver:
  • 4 Answers
One configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
Posted on Jul 24, 2008
Thanks for the assistance. It is a problem that the mfg will have to fix.
Posted on Jun 24, 2008
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
Pics. wont upload to computer no disc
if your camera has a switch for display or camera modes, then you may have to switch it to display mode to view the pics on your computer with the usb cable. When the switch is in the camera mode it will usually try to install it as a web cam and won't show any pics.
Sep 26, 2010 | VistaQuest VQ-5115 Digital Camera
Pics are blank in viewer
there are many reasons that no picture is displayed:
1. there is no picture in the first place. (camera lens closed when picture was taken)
2. you are not on display mode (toggle to display mode not "take picture" or capture mode)
3. defective memory card.
4. you are on display mode but on another sub-mode which does not display pics... (toggle to display, details, etc...)
Aug 24, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I can view the pics i take clearly but when i switch modes to take a pic the screen is black and i hear a clicking sound.. olympusfe-220
I beleive your Memory Card is the problem. Take it out and leave it out when turning it on and see what it does. Mine was doing the same thing untill I did the above and it took a picture with internal memory just fine. If it works, then you need to format the memory card using your camera setup menu. When you turn the camera on with memory card installed quickly push the green play button and it should stay on for you to see the menu.
Jul 20, 2010 | Olympus FE-220 Digital Camera
I CANT VIEW IN THE VIEWER WHEN IN THE CAMERA MODE. IT WORKS FINE IN THE VIDEO MODE.IT WILL TAKE PICS IN THE CAM MODE BUT NO SCREEN.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 23, 2010 | Canon PowerShot SD600 Digital Camera
My viewing screen is black when trying to take a picture but when viewing pics I have already taken the screen is fine and show the pics..any idea what is wrong?
You need to go into the setup menu and turn on the display. This is sometimes turned off when you use the optical viewer or in low power modes. Your user manual will show you how to do this step by step.
Dec 30, 2009 | Canon PowerShot A75 Digital Camera
I have an e500. The viewer will not come on for taking pics.
Unfortunately with the EVOLT E-500 it does not have the capability for a live view LCD screen. You must shoot images using the viewfinder only. The newer Olympus SLR cameras now have both viewfinder and live view LCD.
Jul 17, 2009 | Olympus EVOLT E-500 Digital Camera
No image
79da3bf.jpgWhile in picture taking mode, press that button. It will restore your viewer.
Nov 20, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Wont show pics
CCD sensor faulty and camera will not work in capture mode ... only playback mode. Have new CCD block installed and camera will work fine.
Aug 14, 2007 | Olympus FE-170 Digital Camera
Fuji FinePix F700 Digital Camera Logo
142 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
