Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Wont power on
Ihave a hitachi Projection Tv Model No.50UX22BA
Sn # V5K007882
when I press the power botton the the make click sound then power off,,,
any sugestion would be great...steve
  • 1 more comment
  • papamotts Jul 13, 2008
    Set won't power on. When the power button is pushed the set clicks, but the power light does not come on. On the right circuit board (viewing from the rear, about the center 3-4 inches from the rear a red LED comes on blinks 3 times then stays on until the power button is pressed again.
  • hgerald61884 Mar 19, 2009
    When i turn my set on the relay clicks and only the Red LED Protection lite goes on and i turn it off the Relay Clicks and the Red LED goes off
  • todzebub Apr 16, 2009
    Red Light D975 is the only LED lit....no greens.
    Turn on power hear click but nothing else.
  • 927 Answers
Good day, papamotts;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Posted on Jul 25, 2008
Have Hitachi LE42LS256, SN LE42LS256 SK2J000667 power surges. went off,came back on,could hear sound no picture, then the sound went out.blue on light on set is on, no sound or picture.
The chipset in the TV could be failing, I would say replace the bulb for the picture, however if you are getting no sound its safe to say the motherboard is probably toast. Projection TVs, and HD TVs in general produce a lot of internal heat. Over time it will damage the circuit boards, maybe time for a new TV!
Dec 04, 2016 | Hitachi Televison & Video
I press bottom tv comes on then goes back off
On this model the power board will need to be completely resoldered, that is your problem.
Nov 29, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv comes on then just shuts off will turn right back on
hello it sound like theres may be a dry joint probably in the power supply you would need a strong light and a magnifying glass and soldering iron and some solder
shaun
Apr 08, 2009 | Hitachi 50GX49B 50" Rear Projection...
Remote code for hitachi 50ux22ba for rca universal remote
i need the same thing!!!! can anyone tell me the answer?????
Mar 29, 2009 | Hitachi 50GX49B 50" Rear Projection...
HITACHI MODEL NO. 50u22ba
http://serviceman.site88.net/index.htm
Jun 23, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50ux26b
Good Day;
If you don't hear the rely click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
May 09, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 50UX26B
does the led on the front of the set light up? Is 50UX26B the right model number of your set?
Apr 27, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
HITACHI NO POWER
It sounds like you've lost the primary winding of your High-voltage transformer or the regulator....accordianman
Feb 15, 2008 | Hitachi 51F500 51" Rear Projection...
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
May 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 46ex3bc
I have the same problem with mine. i,m pretty sure that it is the built in surge protector is bad. Try unplugging the tv for 30 seconds then plug it back in and turn it on. If your surge protector has not completely gone bad this might work a few times. mine won't turn on at all anymore.
Nov 24, 2006 | Hitachi 46BX01B 46" Rear Projection...
Open Questions:
Televison & Video Logo
312 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
