Question about GE XL1800 1100 Watts Microwave Oven
No heat in GE XL1800 1100 Watts microwave
We have replaced two fuses is there another one,if so where is it located.
  • 3 more comments
  • Anonymous Aug 09, 2008
    Same thing happened to our GE XL800 last night. We were cooking something in there for like 20 minutes, the microwave got really hot, and then stopped heating food.
    I can only get it to heat now when I put the vent on BEFORE starting to heat something, otherwise, it doesn't heat up.
  • BrokenGEs Jan 24, 2009
    I have similar problem as other poster.  Microwave stopped heating food on Jan 23, 2009.  It WILL heat food if you turn the vent fan on BEFORE starting the microwave.  BIZZARE!!!!  This sounds like it may be a controller board problem since I can get heat out of the magnatron.
  • edavidson55 Jan 27, 2009
    I have the same problem & it started Jan 23 2009 just like yours. How weird is that?
  • sirish_vt Feb 05, 2009
    I have the same model microwave and same problem only hets food when i switch on th vent fan before heating food.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your model number so we can help you.
    NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Posted on Sep 21, 2008
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
Jul 04, 2014 | GE XL1800 1100 Watts Microwave Oven
JES1139 is not working properly. The round table is rotating but the food is not getting heated.What is the problem?
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 23, 2009 | GE JES1139BL / JES1139WL 1100 Watts...
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Does not heat
is there light in it... if its completely dead..if yes, check main fuse inside and then check lamp also...
if it is getting on but not heating then u need to check the magnatron...the source that cause heating..
goodluck......
Aug 14, 2009 | GE XL1800 1100 Watts Microwave Oven
Everything seems to work but it does not heat the food.
Jul 30, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge jvm1650wb005
Mar 31, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE XL1800 1100 Watts Microwave Spacemaker
Yes, it could be the Magnetron. If the unit is out of warranty, you can try to remove the rear cover (make sure unit is unplugged) and see if there is a blown fuse in the section that powers the Magetron. They are not too difficult to replace. MCM Electronics sells them and you can call them with your model and they can find a replacement for you will be able to see how much it will cost.
http://www.mcminone.com/search.asp?keyword=magnetrons
1-800-543-4330
Good Luck,
- Jim
Jan 24, 2008 | GE XL1800 1100 Watts Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
1,500 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
