Question about Saeco Vienna De Luxe Espresso Machine
Can not prime the machine
I have a new machine that won't prime. I have filled the water tank but it won't prime. I think there may be a piece missing. Should there be a small ball or part at the entry point on the machine that would depress the valve at the bottom of the water tank to allow for free flow of the water???
It can't be clogged...it's never been used.
Thanks for your help.
J
  • 40014 Jun 22, 2008
    Can I not get free advise to view the solution or do I have to pay! You say there is a solution but non is shown unless I pay!
  • 515 Answers
I think you have to get a little pump to press down water in the hole where the water tank is fitted, when you open the steam knob then you have to press in water to the machine.
Posted on Jul 11, 2008
Indicator showing a water droplet sign on the left lights up red. What does that means? How to solve the problem?
could be one of two things
the machine is asking to be primed or ventilated , where you turn the hot water on till the light goes out.
or is asking for tank to be filled. There is a magnet float in water tank sometimes it stops floating making the machine think there is no water. to check fill tank with water and look to see if float is floating it will be grey/black in bottom corner of tank
Feb 07, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Won't spray water and cleaner from the machine
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Jan 24, 2010 | Bissell 9200 Upright Vacuum
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Why am I getting a "need to prime" message. I have low water flow when I open the hot water/steam valve to prime the machine as per the user guide.
HI
The problem you have is, there is a restriction in the intake of your flow meter. It usually is a piece of coffee that fell into you water receptacle when you had the water tank off. Then you filled the bean hopper and the chip of coffee fell in the receptacle, and then you replaced your water tank and that let the chip flow to your flow meter and now you have a slight flow of water and you always get the ventilate message.
You need to remove the flow meter (in the back bottom of the machine, attached to the tube that goes to the receptacle) and clean the intake side, and then remember "When you are working on either the beans or water, make sure that the other one is covered".
Jul 28, 2009 | Starbucks Saeco Italia Digital Barista...
"add water" error message.
problem solved! the float in the water tank has a magnet in it that the main unit senses. the previous owner cleaned the tank before shipping and installed the sensor upside down. if you disassemble the water tank, it is very easy to install the float incorrectly.
Nov 07, 2008 | Simplehuman Single Cup Pod Brewer Brushed...
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
I have a Saeco Incanto RS Espresso Machine. The prime light is on, but the machine won't prime. Very little water of steam comes out of the wand.
You need to manually prime it using the priming bulb that came with it. Instructions are in the manual. Remove water tank. Fill priming bulb. Hold priming bulb on water inlet. They don't inter-connect, so just hold it on there as best you can. Turn the machine on, turn steam knob on, and gently, slowly squeeze the bulb to force water into the machine. It works best when the machine is cold, because you want to get liquid water in there, and not have it displaced by steam.
Jun 30, 2008 | Saeco Incanto Classic Espresso Machine
Can't prime new machine
brand new machine you put water in the container prime it with turkey blast open the valve on the side off machine and it still does not work tank good for warranty cheers
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Saeco Vienna De Luxe Espresso Machine Logo
119 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
