Question about Palm TX Handheld
Palm crashes with message "installer not compatible with my device" when I do magnifying glass icon search on Contacts
I do dock my Palm TX regularly to synchronize my Palm with the Palm desktop.  When you say I need to restore my Palm software do you mean the Palm OS Garnet operaing software or the applications Software?
  • mitchr Jun 21, 2008
    I have not been able to find a source to download the PALM OS Garnet 5.4.9.  Can you tell me where to find it?
  • mitchr Jun 22, 2008
    I have no GPS software on my Palm TX.  The Palm OS is Garnet 5.4.9.
  • 2,794 Answers
You should reinstall Palm OS and everything else after that.
Posted on Jun 21, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jun 21, 2008
    I just want to verify the GPS software. Is it Garnet or Garmin?
  • Tim Babcock
    Tim Babcock Jun 22, 2008
    Sorry. This isn't the standard operating system for Palm is it?
  • Tim Babcock
    Tim Babcock Jun 24, 2008
    Sorry for the confusion but I have never heard of Garnett creating an operting system for Palm. Has the operating systems been modified for some special use?
    I know that can be done.
Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
Feb 12, 2010 | Palm TX Handheld
My Palm TX is crashing with increasing frequency. Sometimes one push of the reset button will get it back, but mroe often it requires several pokes with waits in between. It crashes when I 1) start it up...
I would check for Application compatibility.
there might be a conflict issue with your Palm TX and some software in it. there is a site for you to check for compatibility to see if there is a risk or if they are "Approved" for use in the Palm TX
I hope this helps you out in figuring out whats going on with it.
Jun 07, 2009 | Palm TX Handheld
Palm TX won't synch with Vista
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Apr 16, 2009 | Intel Palm Tx Handheld
My TX crashes every time I try to hot sync
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Feb 04, 2009 | Palm TX Handheld
TX in a crash, reboot, crash cycle since I deleted contacts file
When reset button is pushed, the Palm screen comes on in color, then in gray, then the screen goes blank. Can I repair it?
Jan 11, 2009 | Palm TX Handheld
Palm Tx crashes constantly when I do search on Contact
You should restore your Palm software.
Have you docked it recently?
Jun 15, 2008 | Palm TX Handheld
Palm TX reboot
What happens when you press the reset button on the back of the TX?
May 13, 2008 | Palm TX Handheld
Converting from Palm Pilot TX to iTunes
There is probably a compatibility issue between the TX, Pocket Copy, and Iphone. TX is pretty picky about what can be used to transfter information. They only recommend Outlook and the one that is included on the TX CD.
TX and IPhones are different systems as well. You could try to get the files exported from the TX into a CSV and see if you can import the files into Iphone that way, if it will import them.
Good luck on that one.
May 06, 2008 | Palm TX Handheld
Software download to handheld
You must have Palm Desktop installed on your pc. You must have a serial cable from your pc to your handheld. You must have hotsync running on your taskbar. You must download the software to the Palm Desktop and then hotsync your Palm with the pc. You may not be starting the safe hotsync in the start menu before pressing the hotsync icon on your Palm. If it's not that, your pc may not be recognising your Palm device or you may not have your serial cable securely hooked up, or you may be trying to download software that's not compatible with your device. You also have to reset your device after installing most software. Make sure you have enough memory to hold the software.
Apr 02, 2008 | Palm TX Handheld
Palm TX Handheld Logo
135 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
