Question about Belkin (F5D5231-4) Router
Security how can i stop other users outside of my home tappin into my wireless connection gettin free internet access
  • bretten19 Jun 22, 2008
    the make of wireless router is belkin f5d8233-4v3 and the solution i want is the neighbours phonr has been cut off and they are gettin on internet through a nearby router and we are nearest for a fair distance
  • 1,689 Answers
First off, your router is a wired router, if your talking about Hackers, well your router has NAT/SPI, a regular standard for router, it is on and alsways on so you wont have to worry about it.
if you have a wireless access-point plugged in to the router, let me know what is the brand and model and i will be more than willing to help you out.
Posted on Jun 22, 2008
Why cant i access wireless in my home or download
Can you verify if other devices can have access to the internet in your home? If you can access wifi connection elsewhere, then most likely your wireless router is not configured. You didn't specify if it ever has been. Router needs to receive the internet signal from outside the house and make it available through radio. Depending on the make and model of your router, you would need a hard-wire connection between your PC and the router. Then you need to configure it, assign a wifi name, security type and password for it. Write it down on a sticky label and stick it under the router because eventually this info gets forgotten.
Aug 27, 2014 | Microsoft Windows Vista Ultimate Edition
How is a wireless system different from a hardwire security system?
Wireless systems are much easier to install. It really depends on the place you want to secure. Two-story homes are ideal for wireless due to installation ease. On the other hand, one-story homes and business may be more suitable to hardwire systems. There is no difference in the operation.
Jul 18, 2012 | Safety Technology Wireless Home Security...
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
What is security key, when trying to find a connection? I am new at this, I am away from home, I can find a strong connection, I hit connect now, it then prompts me for a security key, what do I need to...
The owner of the Wireless Access Point has created a "password", so that "outsiders", like you, cannot connect to their network, unless the owner tells you what the password (or "security-key") is.
Take your computer to a hotel, motel, public library, Starbucks, et cetera, type of place that offers "Free Internet" to their clients. You should be able to connect.
Jun 15, 2010 | HP Compaq Presario V6000T Notebook
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address:
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
Gateway IP Address:
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Gateway IP 1:
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
When i go to free wifi spots, my dell latitude D800 will not open(the internet), i can access the internet just fine at home, i have internet service at home. how can i get the internet to come up when im...
When you are home, you should hopefully have a secure wireless connection. When you are not home you willl need to change the access point so you can connect to a free wi-fi connection.
When you want to connect to a free wi-fi connection, do this:
Click Start, Settings, and choose Network Connections. Look at the possibilities for connection assuming your PC is within range and the wireless card picks up the signal. Choose from one of the connections - choose the fastest and best one you can find. NOTE that these connections are usually NOT secure and you should not share personal information or do any banking, credit card purchasing, etc on an unsecure connection. Chatting is ok, but still exercise caution....there are lots of bad guys out there who would love to meet you and steal your identity, banking information...or worse. Better safe than sorry.
When you get back home, you will have to change the connection type back again to your home network so you can re-connect there.
Mar 03, 2010 | Dell Latitude D800 Notebook
I've locked the wifi connection so only my laptop can access it how do i open it to make it free for everyone around the wifi router?
Just "undo" what you did to "lock" it.
Then, run the "Wireless Networking Setup Wizard",
and pick an SSID and a password,
and tell the password *ONLY* to your friends/family,
since you don't want somebody sitting in their car, outside your home,
to "steal" your Internet access (for "hacking" purposes).
Dec 31, 2009 | Belkin (F5D7230-4) Router (587009)
How do i secure my intellinet wireless to prevent outside users, i'am recieving e-mails for the people who live across the street.. thanks
WHAT????? thats not the issue then....BUT you need to access your WAN wireless access network and add a PASSWORD.....done by double clicking the wan access point in the cluster of icons in the lower right hand side and gettin to the SECURITY function..
May 10, 2009 | Computers & Internet
Not able to install the software, tells me mdm.exe has stopped working and won't go any farther
Manual Setup: This option is best if you cannot use the wizard on the CD, are replacing an
existing router, or are technically knowledgeable. Follow the instructions in this manual to set
up your router.
Connecting Your Router
1. Connect the router, the computer, and the modem.
a. Turn off your computer.
b. Turn off and unplug the cable or ADSL broadband modem.
c. Locate the Ethernet cable (1) that connects your computer to the modem.
d. Disconnect the cable at the modem end only (2).
e. Securely insert the free end of the cable (1) into a LAN port on the router, such as LAN
port 4 (3).
f. Securely insert the yellow cable (5) that came with your router into the yellow Internet
port of the router (4) and the other end into the modem (2).
Setting Up Your Router for Internet Access
To access the router using its login name and password, follow these instructions.
1. Connect to the router by typing in the address field of your
browser, then click Enter.
For security reasons, the router has its own user name and password. When prompted, enter
admin for the router user name and password for the router password, both in lower case
Enter the user name and password. The router will display its home page.
When the router is connected to the Internet, click the Knowledge Base or the Documentation link
under the Web Support menu to view support information or the documentation for the router.
If you do not click Logout, the router will wait 5 minutes after there is no activity before it
automatically logs you out.
Set Up and Test Basic Wireless Connectivity
Follow the instructions below to set up and test basic wireless connectivity. Once you have
established basic wireless connectivity, you can enable security settings appropriate to your needs.
1. Log in to the router at its default LAN address of with its default
user name of admin and default password of password, or using whatever LAN address and
password you have set up.
2. Click the Wireless Settings link in the main menu of the router.
3. Note that the default SSID is NETGEAR.
4. Set the Region. Select the region in which the wireless interface will operate.
5. Click Apply to save your changes.
6. Configure and test your computers for wireless connectivity.
Program the wireless adapter of your computers to have the same wireless network name
(SSID) as the router. Check that they have a wireless link and are able to obtain an IP address
by DHCP from the router.
Apr 19, 2009 | Computers & Internet
Belkin (F5D5231-4) Router Logo
88 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
