Question about Apple iPod MA446LL/A MP3 Player
IPOD is not wokring.
I am not able to turn ON my ipod. when i connect to the laptop, it start blinking with apple sign... please help me....
  • Apple Master
  • 2,794 Answers
What happens when you unplug your Ipod and press the center button while hold down on the menu button?
Posted on Jun 21, 2008
Ipod touch 1st Gen turns off during restore. (Need Help!) Please?
You might want to try holding the top button and the home button until it turns on, then let go of the top button. Keep the home button held down until the "Plug Into iTunes" picture comes up. You should be able to normal restore now. If this doesn't work, just go get it repaired.
Oct 16, 2009 | Apple iPod touch
I cannot sych my iPod Touch with my laptop....
You will find the instructions to re enable your iPod at the link below.
http://support.apple.com/kb/TS1567?viewlocale=en_US
Sep 12, 2009 | Apple iPod MA446LL/A MP3 Player
No disc
Please visit the online link for Apple iPod and download the prescribe driver for your iPod in order to recognize your iPod in your current system. Please click Apple iPod.
Thanks
Aug 12, 2009 | Apple iPod Photo MP3 Player
My mini ipod freezing, showing charger sign i could not turn it to menu
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
Can't use my ipod 20gb
Can you charge it? If so fully charge it and then connect it to the computer and reset/rebot the ipod and see if that helps, if you can't charge it just do the same thing.
Dec 11, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Restore
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more asistance, let me know. Good luck.
Mar 23, 2008 | Apple iPod 4th Generation MP3 Player
Apple 20GB IPOD 4th generation
I have the generation one which was developed in 2005 and mine does the same thing. What i do is hold the menu button and center button down at the same time until it resets itself,this should only take nomore than 30 sec. of holding them down at the same time. That should help.
Jan 19, 2008 | Apple iPOD 20GB Toshiba Harddrive for Gen...
Help please...
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Play/Pause and Menu buttons until the Apple/iPod logo appears, about 6 to 10 seconds. You may need to repeat this step
Oct 21, 2007 | Apple iPod MA446LL/A MP3 Player
Mini ipod freezing showing charger sign
restart your pc press del key in your keyboard,
go to setup usb settings disable usb 2.0 setting
Sep 15, 2007 | Apple iPod mini M9160LL/A MP3 Player
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
19 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
