Question about Compaq Presario 700 470024-192 Notebook
NO POWER/NO BLUE LIGHT
My power adapter plug into the laptop broke so it was soldered at the end. It shorted out and now there is no power thru the machine when I try another adapter that does work on another machine. The blue power light also doesnt light up. Any ideas?
  • 46 Answers
Eww.... Probably it's something related witht power supply of the laptop....Contact hp.....
Posted on Jun 28, 2008
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Feb 16, 2013 | HP Pavilion Computers & Internet
The adapter stopped charging my laptop due to a faulty wire, I bought a new adapter and now as soon as I plug in it starts for a second and turns back off. The charging light blink and it doesn't
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | HP Compaq Presario C509NR Notebook
Male tip of charging point for Acer a500 broke off
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 09, 2012 | Acer Computers & Internet
Cannot bootup . Screen lites up with choices--safe mode,safe mode with networking, safe mode with command prrompt, tart windows normlly. useed up/down keys for eah selection and no results. Should blue...
When you connect the power adapter into the laptop, does the blue power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Jan 26, 2011 | HP Pavilion ze2000 Notebook
Its my sister's toshiba a205-s4577 it does not boot up at all. when i plug in the ac power, the blue plug light goes on, but when i press the power button, all the lights flash for a second and then...
Hello.
The most common reasons are the battery, power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you are knowledgeable, remove the heatsink and apply new thermal paste.
But, it certainly could be the mobo.
Hope this helps.
Jan 24, 2011 | Toshiba Satellite A205-S4617 Notebook
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
A105 won't power up...no power adapter light on
Did you experienced any overheating before that happened?
Apr 11, 2010 | Toshiba Satellite A105 Notebook
I replace the dc power jack on a toshiba satellite a215-s7437 with a radio shack dc connector soldered the jack on and put back together when I plug it in the blue adapter cord lights up along with the...
this sound like there is a short in your soldering, did you solder the port directly onto the motherboard. just go over all the joints and make sure there is no shorts
Mar 28, 2010 | Toshiba Satellite A215-S7437 Notebook
HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 18, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
HP zd8000 laptop power supply
I found the solution - and implemented it, it works. The blue (ID) line needs to show 7.5v. The simple way to acheive this is to simply put a 47k resistor from the +19.5v line to the ID line. Apparently there is a pull down at the computer end that means it ends up at 7.5v.
I cut the cable about 6" from the old HP power supply. I then soldered a female power socket onto the loose cable and soldered the 47k resistor between the ID line and the +19.5 line. I then plugged this onto my two pin power supply and the plugged it into my computer. It works very nicely.
Not wishing to junk the HP power supply unecessarily - it was still producing the 19.5v - I then soldered a power plug onto that ignoring the ID line. That now works as well. It seems that the circuitry that provided the 7.5v ID voltage in the HP power supply became flakey. I could have just opened up the power supply (I have already done that) and disconnected the blue line from the circuit board and just tied it to the +ve line via the 47k resistor and then wrapped it with the usual insulating tape.
Mar 27, 2009 | HP Pavilion zd8000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
