Question about Pyle Audio Players & Recorders
Wiring diagram for a Pyle (PLCAPE12) 1.2 Farad Digital Power Capacitor
How do I select speaker a or b on the Pyle PT26-A
Pyle products are aimed at the value end of the market. So features get omitted that are deemed "not important" in order to k=get to very low prices. One of these features is the Speaker A/B A+B button.
To implement that feature properly means doing some decent design in the power amp section to handle the switches in load. It also requires a stronger power supply and amplifier section with real guts. These are not Pyle strengths. They're built to a minimum specification.
So the answer is that there is no Speaker A/B A+B switching. Both sets of speaker terminals run all the time.
Sep 10, 2014 | Pyle Audio Players & Recorders
Sound used to be clear. Now have static. Is my pyle PT54 digital tuner bad? I also get a loud hum when the unit is tunred off.
Sorry, but Pyle isn't good gear. If you've checked all the wiring and nothing else has been altered then I'd point the finger at the Pyle-o-c***
Sep 03, 2014 | Pyle New-Home Pt504 Rack-mount Am/fm...
My pyle motorcycle speakers make a low buzzing sound when power unit is shut off
If the engine is running when this happens it is because of the charging circuit for the battery. The alternator is not sending out a clean charging current.
Jul 24, 2014 | Pyle Audio Players & Recorders
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
I have a pyle pro pta3000 power amplifier,when i hook it up, one channel works fine and the other channel works intermittenlly.
you either have a cold solder joint or a bad capacitor or a bad input.
if it's only happening from one source, look to the source as the issue - there may be a DC voltage riding on the output into the amp, saturating the input until the caps charge...and if there's a bad cap on the input or output, it may take time for it to stabilize.
Meter the input at zero signal, and meter the output as well looking for DC voltage riding on it.
compare readings at zero signal between channels for discrepancies.
ground both inputs and start metering .
check the low ohm resistors between the output transistors unless it's a hybrid.
when I say transistors I mean mosfets.
Mar 20, 2011 | Pyle Audio Players & Recorders
Have an infinity entra sub two. Has burnt capacitors at c72. Has two capicitors, (one on each side of pc board) need to know values
The values will be printed right on the capacitors themselves.
it will look like 1000uF 25V for example. That would be a one thousand micro-farad capacitor at 25 volts.
You may need to pull the capacitors to be able to read them.
Feb 25, 2011 | Audio Players & Recorders
Loosing memory
Need to replace backup capacitor 0.047 Farad 5.5v capacitor at front board.
ebcelectronics.com
Jan 20, 2011 | Harman Kardon AVR 7000
HARMAN KARDON 630
If this is an older type receiver, yes there is a special capacitor inside to control the memory. Where it is at is the trouble. I do not remember. You will need to get a service manual to locate it. Good Luck
Jun 30, 2007 | Harman Kardon AVR 630 Receiver
758 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
GERHARDUS STROEBEL
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
