Question about Roper RS22AQXKQ Side by Side Refrigerator
Ice maker gets hot
Ice maker filled with water and after an hour I checked the ice maker and it was hot and the water in it was hot. the freezer part works fine.
    Genius:
  • 1,036 Answers
Sounds like a fault on the control board.
It's supposed to go through a timed sequence of filling, freezing , warming and emptying.. It seems to have stuck in the (brief) warming stage.
Try disconnecting and plug in again after 1/2 an hour.
If it is still under warranty, get this sorted as a priority.
If it will not reset, then a replacement control board is the only option.
Posted on Jun 21, 2008
My ice maker stopped working
Test the ice maker cycle button on the bottom of the ice maker, if it cycles and fills, replace the ice maker because that is bad. If it cycles and doesn't fill, you could have a few waterline related issues. Check the water pressure out of the dispenser. If it's very slow Unplug the unit for 24 hours, increase the water pressure to the unit , get all of the moisture out and see if it fills after you plug it back in. I bet it's the ice maker though.
Jan 22, 2015 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
My ice maker stopped producing ice. help
One quick test would be to manually put water in the ice maker and wait a few hours. If it does push the ice out, that means the ice maker is working. If it did not refill the ice maker with water the valve (in the back) may need to replaced. It is also possible that the fill tube inside the freezer is frozen. Another thing to check is the temperature in the freezer. It has to be 10 or below for the ice maker to start a cycle.
May 26, 2011 | KitchenAid Refrigerators
No water going to the ice maker
You could have either the ice maker causing this or the side of the water control valve that feeds the ice maker is defective. Here is a simple test to see which is causing the problem. Fill ice maker with tap water. If after the water freezes the cubes drop into the ice bin then the water does not refill it will need the dual water control valve replaced. If ice just sits there then the ice maker needs to be fixed or replaced depending on your Maytags model number. Let me know the model number and results, Thanks, Sea Breeze
Mar 18, 2010 | Maytag Refrigerators
I had the power out on my refrig for about 8 hours. Now the ice maker has stopped making ice. Water in the door works, but no water going to the ice maker and not dropping ice. Do I need to defrost the...
There is a dual acting water valve that feeds the ice maker and door water seperately.
If your power went out - chances are good the solenoid on the icemaker side of the valve has failed - so it will not open the valve on the demand of the icemaker timer.
To find out - you will need to check that there is voltage at the valve.
With a model #, I can help you better.
Thanks!!
Feb 20, 2010 | Refrigerators
Water to ice maker leaking in freezer
I emptied out my freezer. Turned it off and made sure it was dry and clean. Then I turned it back on, but left the metal wire that controls the ice maker up so water wouldn't fill until freezer was cold enough. When cold enough, I dropped the metal wire down and kept a close watch of the filling process. Everything went smoothly. No problems in this first 24 hours. I think ice must have built up and letting it thaw and dry made the difference.
Oct 20, 2009 | Amana Refrigerators
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
WATER RUNS DOWN FREEZER WALL
SRCTE,  Are you certain that you installed a NEW water valve?  To isolate the problem between the ice maker and the water valve.  Remove the ice maker from the refrigerator.  Inspect the water fill tube for being stopped up with solid ice.  If so, clear the solid ice with a hair dryer blowing hot air into the end of the water fill tube.  Insert a long screw driver into the end of the water fill tube to break loose any remaining solid ice up in the tube.  Inspect with a flash lite to verify the water fill tube is clear and open.  Leave the ice maker out of the refrigerator overnite and operate the refrigerator as normally used.  After 6-8 hours, open the freezer door and inspect the end of the water fill tube; if the water fill tube is clear of solid ice then you have a bad ice maker which must be replaced.  If on the other hand the water fill tube has ice protruding from the water fill tube then the water valve is defected and must be replaced again.  If the water valve is replaced you may desire to install an external in line water filter. Hope this helps you.  Henry
Feb 06, 2009 | Refrigerators
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Roper RS22AQXKQ Side by Side Refrigerator Logo
56 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Mike Cairns
Mike Cairns
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
